Question about Dell E177FP LCD Monitor
LG flat panel
LG 19" flat panel will not come on. all it shows is digital power saving mode, in a blue box. the e-machine is working but the oanel will not show any thing.
  • 472 Answers
Due to no model number I will assume it has bith digital and analogue inputs.
If possible, connect another cable the opposite of what you are using and try it again. (IE: if you are using a DVI cable now, use an analogue instead)
It is possible that the internal video card of the monitor has been shorted out and will not accept a signal any longer.
On the upside, if that is the case, the digital and analogue circuits are normally seperate to each other so losing one dosn't mean losing both. It could also be the output section of your PC's video card that has suffered the same fate so try the other video port (if you have 2 on the same card) or try another video card.
Posted on Apr 08, 2008
Automatically power saving mode ...........................cpu start working..........monitor power saving mode
Hook a spare monitor to the computer, if the same symptoms occur the problem is the Video Graphics Card in the computer, but if the picture is okay, it is clearly the LG Flatron that has the problem, and if possible sub the video cord from the computer to the monitor just to be sure.
Mar 10, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
When i on my pc then the lg screen show me message analog power saving mode and then screen turns black. how can i overcome this problem
I would say that it doesn't see any signal coming from the computer. Check your output. Check the video drivers. Try another video display.
Aug 10, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Out of the blue one day, monitor started displaying "anaolog power saving mode." This is a stand-alone computer which has never been hooked up to internet.Took tower unit to PC World to see if it was a...
you go to control panel starting your pc ,, then display settings,, from there,, screen saver tab, then make screen saver to none, and click on button power,, there you make everything to never,, and then see. it should work good
Sep 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Analog power save mode
Are you connect via Analog (Blue VGA connection) or DVI (White Digital connection?
If you are connected via DVI, then you have to change the input select button to DVI
If you are Connected VGA, make sure the system doesn't have 2 VGA ports. If it does, connect to the other port.
May 02, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Power saving mode
What brand is your laptop? Sometimes you have to manually switch between your laptop and an external monitor. Usually pressing the "CTRL" button and "F5" might work to switch the signal from laptop external.
Mar 19, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Analog Power Saving Mode
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Dell E177FP LCD Monitor Logo
60 people viewed this question
Alun Cox
