Question about HP Compaq Presario SR1520NX (PX801AA) PC Desktop
PC wont go on & beeps...
I un pluged Pc & now I have one plug (power Pack)?one end goes in wall outlet,the other end looks like a headphone plug.
I can't fine circle to put it in
Pc beeps & black screen monoter blank.
I have a scanner/printer connected to pc & Router & Net Gear for a lap top in another room.Lap top works.
Help I can't find any pictures to explain what this wire is for.I'm hoping
thats the problem with PC. Thanks Kathy
  • 298 Answers
Thats mostlikely one of the wire's for your speakers, printer or any other device yuo have that needs power..
If so that wont help your pc in any way.
I'd untangle and trace the wire back to see where it's coming from to be safe.
Also if your pc is plugged in along with your monitor and you can turn both on and you still get an error, then you have a problem. I'd submit a new question detaling the error or beeps your getting.
Posted on Apr 19, 2009
    Problem Solver:
  • 9 Answers
Mother board Is False
When tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Oct 13, 2015 | Televison & Video
Need USB power cable for laptop cooling pad
I suspect you're probably looking for a micro USB B male plug for the cooling pad with a male micro USB A plug on the other end of the cable, which you would plug into a computer or AC/USB wall outlet adapter.
There are also cables which plug directly into the wall outlet and have the right male USB plug on the other end, but they tend to be harder to get and many times are more expensive.
Apr 08, 2014 | Computers & Internet
Power pack light red
Hello, let's try a few things. First I would try to unplug the cables at all points. The wall, unit and power block in the middle. Reconnect and see if that helped.Be sure the unit is straight to the outlet and NOT to a surge protector or power supply or extension cord.
If not, I would try to plug the unit into another outlet somewhere. In a different room or something. Be sure the unit is straight to the outlet and NOT to a surge protector or power supply or extension cord. If that works, it's clearly the outlet in the original spot.
If none of these solutions help, if possible, see if you can borrow someone else's power supply and give it a try. If it works, then you know for sure that's all you need to replace. If it still doesn't work, you may have an internal power issue and will need a repair.
You can also find Microsoft's power supply trouble shooting guide here.
I hope this helps :D
Nov 24, 2011 | Microsoft Xbox 360 Console
A low humming noise
A low quality power supply pack (brick) to the wall outlet is most likely to be the cause of your problem.
Look for the power supply pinout and test it with a replacement power pack.
Plug the power pack onto the same power strip of the audio source (Example: your tuner) will also help rule out grounding problem.
Turn off any motor operated item (example: heater fan) to rule out noise from other appliance.
Apr 24, 2010 | RCA WHP141 Consumer Headphones
My acer aspire 3680 wont power on. i pluged it in and the wall outlet kind of sparked and now my computer wont come on at all
Hi did you try plug in other wall outlet to see if its the charger that is bad? and you can try using another charger 1 you sure is working this will determine if it is the charger or computer is damage.
thank you
if my advice is helpful kindly vote for me
hbristol173
Mar 31, 2010 | Acer Aspire 3680 Laptop
About 3 times a day the external battery pack for the computer beeps really fast. Then stops.
Most "desktop" computers do NOT have an exernal battery pack. If your does, that's OK.
The "beeps" probably occur when the AC power from the wall-outlet is interrupted (or is cut-off). The charge in the battery continues to supply power to your computer -- so, your computer does NOT crash.
Jan 13, 2010 | HP Pavilion M9040N Elite Desktop PC
Emachine wont start up
This is a DESKTOP machine, not a laptop. It has to be plugged into a wall outlet that has power, for the machine to run.
Jan 05, 2010 | E-Machines eMachines Desktop PC
Hooking up speakers
On the back of your computer tower (that thing with the power button on the front) you should see three small headphone jack looking thingies, with colored bands around them. Your speaker cord plugs into the green one, if you have a microphone, it goes in the pink one.
Your speaker set should have a wall wart type power supply, plug that into any convenient outlet, and plug the other end into the proper jack on your speakers.
The volume knob on your speakers is also an on-off switch, turn it on.
Apr 17, 2009 | HP Computers & Internet
Turning on i guess
It should work OK once you plug it back in. Note there are three places to check the power connection.
- The power pack has to be inserted firmly
- the cord that goes into the power pack
- the cord into the wall - be sure to check the wall outlet with a lamp or something to make sure it's not an overall power problem/breaker, etc.
Steve
Sep 11, 2008 | Lexmark X5470 All-In-One InkJet Printer
Laptop wont turn on philips freevents x51
try this with no battery installed..just plugged into power pack to wall
Jun 15, 2008 | Computers & Internet
HP Compaq Presario SR1520NX (PX801AA) PC Desktop Logo
103 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
