Question about Garden
I have a poulan leaf blower and can't get it to crank. Have replaced the coil, carburetor, spark plug and using new fuel.
  • chris stovall Apr 19, 2009
    it was not the coil but the ignition module
  • 398 Answers
SOURCE: Homelite 26D leaf blower bogs down in Run position
check the air filter.
Posted on Mar 02, 2009
  • 15 Answers
SOURCE: Poulan Pro 200 Leaf Blower won't start. I have
Ok. Good job on doing what you could, right off! The simplest things are the most overlooked, and the most unforgiving.
So, you know your plug is wet, so you got some fuel flow.
Now let's figure out the plug no-fire problem. (This is under the assumption you haven't beat on this blower with a sledge-hammer at one point. The whole "key-way" is fried thing.)
1. Grab ahold of that plug THEN crank away. One time will tell you yes or no on spark. No, I am not joking, and yes, it is better than staring at the end of a plug and wondering if your eyes are bad.
In fact, better than a cup of coffee......in a bad way.
2. Check your kill switch. It is either: Grounding, or Open (open like it should be, UNTIL you push it, click it, or slide it, whatever you got). One CHEAP and fast way: Unhook the kill switch.
Then crank away. No spark? Not the kill switch then!
3. Check your spark plug GROUND. Let's say you got some shocking results from grabbing onto that bad boy. NOW check where the plug meets the cylinder head when she is screwed down in there. Believe it or not.....if it is funky, she won't ground right!
Hence, no worky.
4. You got no spark at all.....STILL. Let's look over your Spark Plug WIRE. Is she wore through? Is SHE grounding out? Has she heat failed? Then do #5.
5. STILL no spark. Let's check the last 2 things......
Rotor Magnets, and Magneto (ignition coil).
IF you have a volt/multi-meter, hook her up to the plug wire. No juice = Bad Magneto, or Bad Plug Wire. SOME juice = Good Magneto, but Bad Plug Wire (in some mowers/weedeaters, etc., remember that the Magneto is where the kill switch hooks too.
See if it is somehow grounding you out, by being loose but still touching the cylinder, etc.)
6. Failing Magneto. This can happen, and it does. You get SOME juice, just not ENOUGH juice. 2-Strokes make a lot of heat, even Magneto's give up the ghost after a while, sometimes. In this case, find a replacement!
Posted on May 30, 2009
  • 15 Answers
Alright, remember that 2-Stroke motors are meant to do 2 things:
Break down, then Frustrate you.
So, here we go: (Electrical)
Rotor Magnets, Magneto (ignition coil), Spark Plug Wire, Spark Plug, Spark Plug Ground (Cylinder Head).
In that order!
Check your "fire" from the Magneto:
1. Check your Kill Switch. In other words, leave everything normal, and unhook it. Did she start? Kill Switch it is! Kill Switch/Wire comes from the Magneto (single wire/ground) to the Switch itself. So check that wire AT the Magneto (Is it loose and grounding out? Is the Kill Switch grounding you out where it is, because of crud, junk, or because it is touching the block when it is not supposed to?)
2. Check your Spark Plug Wire. Easy, unook it from the plug, stick your finger in, give it a crank (non-MultiMeter way). Did you get shocked? Then it ain't your Plug Wire and Magneto!
With a Multi-/Volt Meter, simply hook her up, and check for juice WHEN you pull the rope. If you got juice, it ain't your Plug Wire or Magneto!
Checking Spark the "normal" way: Grab the Plug with a pair of insulated pliers, hold the plug end against the cylinder head, and pull your rope. Any Spark? What color?
3. STILL no fire. It leaves: Magneto and Plug Wire.
Luckily, they are both in the same place! Tear your blower down, and check to see if the Magneto has slipped out of place (gap is WAY out), or if the Plug Wire has worn to the point it is grounding you out. While you are there, check your Kill Switch wire, to see if she is grounding you out then and there.
4. STILL no fire. That means: Magneto Failing, or Magneto JUNK.
Buy another one, replace it! (Or steal one from another junk Blower/Weedeater. These things are fairly standard, and easy!)
Or, Bad Plug Wire. Meaning she has failed out on you.
Wait......that means: Replace your Magneto! Lucky the things are built together right?
#1 Taper
  • 1040 Answers
SOURCE: poulan pro leaf blower doesn't start
As long as it has fire, all you need to do is:
Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris.
If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Posted on Jun 09, 2009
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
Howdy I'm unable to keep my Poulan Pro PBV200 leaf blower running unless I keep the choke three quarters of the way closed. Gas and oil mix is new and changed spark plug. Could the exhaust be blocke
Yes, There is a spark arrestor screen on muffler. It could also be a carburetor that needs rebuilding or a simple fuel mixture adjustment.
Jan 01, 2015 | Poulan Garden
I RECENTLY HAD A PROBLEM WITH A POULAN BVM200FE LEAF BLOWER NOT OLD AT ALL WAS WORKING IN YARD AND BLOWER JUST STOPPED WORKING I HAD FUEL BUT NO SPARK I REPLACED COILPUT IN BUSINESS CARD FOR GAP AND S
First let me say I don't know of an aftermarket coil made for this blower.
Disconnect the kill terminal of coil and see if it is generating a spark. There could be a short the wiring if it is now generating a spark. Also make sure coil has a good electrical ground to the cylinder. If coil is not generating a spark with kill wire off and the coil to cylinder ground is good then coil is most likely bad.
Nov 30, 2014 | Poulan Garden
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Put new spark plug in new gas clean filter followed starting directions want start
The fuel system may need tending to. It may need new fuel lines, a cleaned fuel filter and the carburetor cleaned and adjusted. If this is an older unit, (even a couple years old) it may require some new internal carburetor parts as well. I don't like being the bearer of bad news, but this isn't always an easy fix. Your specific problem has to be diagnosed and by process of elimination, the problem resolved.
Oct 05, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
No Spark, plug is good
Hi
If you have a good plug in still no spark you will need to install a new coil.
Sam
Jan 07, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Pro won't start
1. You may have old gas in the tank.
2. Fuel mixture may not be quite right. Pour out and put new in it. Otherwise you may need to clean the carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Nov 29, 2009 | Poulan Featherlite Gas Blower, with Low...
My weedeater leaf blower never gets up to its' old speed. Runs about 1/2 the power. Tried a new spark plug and air filter. New gas didn't help.
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 11, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My Poulan Pro 200 model #200pbv200le will not start.Replaced the carb, fuel, fuel filter,plug. When I pull the cord sometimes I see a spark, sometimes- most of the time I don't see a spark.Replaced fuel
Check your compression...if it reads anything less than 100psi you need to tear it down and replace the piston ring. Looking for the spark is unreliable, get an in-line spark checker and check for spark. Loss of compression due to a stuck piston ring is very common in the pbv200 series.
Aug 31, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
POULAN 200 mph blower. New spark plug last fall.
You will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
Jim
Jun 15, 2009 | Poulan Garden
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
