Question about Beko 24 in. D3421F Free-standing Dishwasher
Bosch dishwasher model S5E56B burning smell
Help. About 5 mins into cycle dishwasher smells of plastic burning. Does anyone have a similar problem?
  • 641 Answers
SOURCE: Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Posted on Sep 02, 2007
meoloncaulif
  • 19 Answers
SOURCE: Dishwasher will not cycle, stops and its filled with water.
try kicking it.
Posted on Jul 05, 2008
SOURCE: Bosch dishwasher stinks/smells
I put an enzymatic drain cleaner in the drain at night, ran it for about 20 seconds (to move the drain water into the hose and then ran it on the shortest cycle in the morning. I repeated it the next day. Seems to make a big difference. ONLY USE ENZYMATIC OR BACTERIAL BASED DRAIN CLEANER.
Posted on Sep 11, 2009
SOURCE: Bosch Dishwasher Classix
I've had the same problem TWICE. It seems the natural vibration of the machine loosens wire nuts and leads to the problem. Soldering the connection and then placing a yellow wire nut over the soldered connection works fine to stop the problem. This machine has a electric water heater to sterilize the dishes and draws a lot of power, near the limit of the connection, more than a standard dishwasher. I called Bosch twice about this problem, only the second time when I stated that my lawyer might call them back did they admit that there is an issue with the vibration of the machine leading to the wire nut becoming loose and suggested I solder the connection. Great dishwasher, lousy customer service. They have know about this problem for years.
Posted on Nov 07, 2009
  • 50 Answers
SOURCE: water no going into dishwasher
check your voltage at water solinoid. if volatage present. replace valve. if none check level switch or vater level sensor. most likely if no voltage will be control.
Posted on Aug 01, 2010
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
BOSCH DW burned plastic smell, common problem?
I have this exact same smell issue from the back black panel at rear of dishwasher (free standing so easy to pinpoint. I replaced the old bosch with this Bosch (approx 12 months ago) for the same reason, and am extremely disappointed to have the same issue. It is almost as though the black insulation material is disintegrating? I wonder what it is made from? Smells noxious. It is very hot to touch during a cycle too. Good luck,
Fiona
May 03, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Smelled like burnt board
Just so you know. Bosch has a 5 year warranty on any printed circuit board (excluding labor) so you pay only for labor charges. They have a 2 year warranty (again excluding labor) on the entire dishwasher. I am leaving a copy of my owners manuals warranty information I hope this helps.
Extended Limited Warranty: Bosch also provides these additional
limited warranties:
• 2 Year Limited Warranty: Bosch will repair or replace
any component that proves to be defective in materials or
workmanship (excludes labor charges).
• 5 Year Limited Warranty on Electronics: Bosch will repair or
replace any Bosch microprocessor or printed circuit board if it
proves to be defective in materials or workmanship (excludes
labor charges).
• 5 Year Limited Warranty on Dish Racks: Bosch will replace the
upper or lower dish rack (excluding rack components), if the rack
proves defective in materials or workmanship (excludes labor
charges).
• Lifetime Warranty against Stainless Steel Rust Through:
Bosch will replace your dishwasher with the same model or
a current model that is substantially equivalent or better in
functionality, if the inner liner should rust through (excludes
labor charges). Bosch will replace the stainless steel door if the
door should rust through (excludes labor charges).
The foregoing timeline begins to run upon the date of purchase, and
shall not be stalled, tolled, extended, or suspended, for any reason
whatsoever.
Repair/Replace as Your Exclusive Remedy: During this warranty
Jan 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Smelled like burning plastic
Ron, is this a dishwasher or clothes washer? If a dishwasher, check the wire nuts in the junction box. If there isn't a melted wire nut from a loose connection. Then you have to pull the outer door panel, then you can pull the control panel assy. This will require a t20 torx bit.
Jan 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
reove screws holding on outer panel and unplug all the leads ( they are all coded so you cannot cross them ) open up plastic cover on module to reveal circuit boeard
Bosch Model SHU4006C Dishwasher
I just bought a Bosch made for Sears and I'm trying to return it. I'm going to get a Kitchaid instead. We got ours two months ago and Sears is being difficult in letting us return it. I had a technician come to the house and he said it smells--slightly oily or rubbery. I went to a store and all of the Bosch dishwashers smell. Anyone reading this, don't get the Bosch.
Jan 03, 2008 | Dishwashers
Dishwasher Stinks
is your dishwasher less than a year old? if so you need to call bosch and have all the gaskets replaced. they tried a new chemical to make the gasket but now have found that after the dry cycle the gaskets put off a strange odor like your discribing. ive changed several gaskets because of this
Nov 27, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch diswasher
If it is new- then the fishy smell is almost certainly the motor and circuit boards 'cooking' in- most motorized electrical devices have an initial pong. However if it persists after say 10/15 cycles begin to suspect an incipient fault.
May 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Beko 24 in. D3421F Free-standing Dishwasher Logo
174 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
