Question about Whirlpool Duet GHW9150P Front Load Washer
I need to change the switch of a washing machine, cannot open the lid (whirpool)
  • 85 Answers
Hi there.remove the screws at the rear of the lid,then push the lid backwards,from the front.its held on by pegs that lock into the lid.hope this helps,steve
Posted on Apr 19, 2009
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool washing machine water not coming into the machine when lid is up and no response from any adjustment to the knobs, it work fine that last time it was use and this morning not responding to...
there's a lid switch on the right side when you open the lid,it might kill the power when the lid opens while filling,you can stick a screw driver in there to check it,you have to send the model number and tell me what it's doing,is it filling and then not doing anything or what's happening with it,does it fill with the lid down?
May 14, 2011 | Washing Machines
Whirpool Ultimate Care II - Top loading washer The water will not drain prior to the spin cylce - Please help
The lid switch is the most probablle cause for this problem.Check the lid switch lift the lid and close it if you cant hear a click replace the lid switch.
Dec 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Need to replace lid switch.. How do i get to the switch
The following link explains the steps required to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Your washer is manufactured by Whirpool, so these procedures do apply. If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Aug 06, 2009 | Roper RAX4233PQ Top Load Washer
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Washing machine stops working
I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
Nov 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
MY WASHER STOPS ITS CYCLE WHRN IT GETS TO SPIN,BUT IF I PRESS REAL ******* THE TOP THE TIMER KICKS BACK IN
Sounds like you have a lid switch problem. The machine thinks the lid is open and it is designed not to run with an open lid. Depending on the styl of whirpool washer you have there is two ways to fix it. First raise the lid of your washer. Do you see a pin on the underside of the lid and a hole in the top of the machine it would fit into? If you don't, try tightening the 4 phillips screws on the hinges on either side of the lid. If they get loose the hinge wont strike the lid switch. If you do see the pin and the hole I mentioned, you likely will actually have to replace your lid switch. If you have this style, send me back your model number and I will type you up a step by step replacement of it.
Jun 26, 2008 | Whirlpool Washing Machines
Whirpoo washing machine stoped
make sure there is power (tripped breaker from jammed pump) check the lid switch & or timer
Mar 10, 2008 | Washing Machines
Whirpool Ultimate care II
your lid switch is broken you need to replace it look on the lid of the unit you will see a plastic pin that pushes down on thwe switch when it closes there are 2 screws holding the switch in place but you will have to remove the cabniet to change the switch
Jan 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
