Question about Vacuums
Bottom on the vaccum the spin brush will not spin at all
The brush on the bottom doesnot spin
    Scholar:
  • 39 Answers
Double check for anything that might be holding it from spinning (shoe lace, string, hair, ribbon, etc)
If the brushes are free to move by hand, you most likely have either a broken belt or a belt that simply came off the motor. What you'll need to do in either case, is open up the vacuum cover. The screws are usually located at the bottom of the vacuum (where the brushes are) and remove all the visible screws you see.
Most of the time (being that I don't know what kind of vac you have, that is enough to remove the top cover off for you to inspect either the motor or the belt which attaches to the motor. I know on my hoover, the belt slips off very easily, so I always need to keep my screwdriver handy to perform this.
Hope this helps.
Posted on Apr 19, 2009
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
The spinning brushes on the vaccum no longer spin, how can i fix this? The vaccum picked up a very small wire from a video game and i turned it off immediately. I unwound the wire but the brushes no...
You have either broken the belt or more likely the clutch easiest is to replace cleaner head assembly £75ish or call Dyson and arrange a service if you're not DIY inclined but check belt !st
Oct 31, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
The main brush will not spin
I would guess the belt is broken. That happens often. Get a correct belt. Remove the brush roller. Wrap the belt around the roller and drive peg. Reasemble -- easier said than done, but keep trying.
Sep 27, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
May 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vibrates very loudly when brush starts spinning
take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Apr 23, 2009 | Vacuums
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Hoover Empower Widepath, brush won't spin.
The belt needs to be changed, it's probably spinning in place which is causing the smell (burnt rubber).
Dec 04, 2008 | Sandia Plastics Super Hipster Power Hepa...
Vaccum has no suction
Need a new belt -- you might have suction but you need the brush to spin (hard to help without make or model, upright or canister)
Oct 17, 2007 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
462 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
