Question about Cyberhome DVR 1600 DVD Recorder
Doesn't hold the current date when turned off
I have tried numerous times to record a dvd without success lately. The dvd player date always reverts back to 1/05 when powered off and I thinks this prevents a timed recording. I have unplugged for several hours and reset to no success. I am able to record instantly but time delayed is not responding.
    Problem Solver:
  • 5 Answers
There is a battery on the motherboard, next to the power supply connector, which may be bad or not connected securely.  That's the first place I'd look, although it should produce other symptoms, especially inability to 'remember' other setting, such as channel memory.
Posted on Oct 17, 2007
After retuning lost access to record / playback on menue and a games button has appeared instead. Have tried turn off/onn and revert back to factory on numerous times without success
Also be sure to include your model number when asking questions, it helps a lot. Always try to check your owners manual to see if there is a reset to factory button or series of buttons to reset device.
Sep 01, 2015 | Televison & Video
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
Date keeps resetting to 27.03.2011 I have tried unplugging,changing the date and going back to factory default and reinstalling but nothing seems to correct the problem therefore unable to use timer
Most DVR's don't have back up battery for holding setup data like your Computer. That means that you can never unplug or switch off the power supply completely. The clock runs off the mains supply so any interruption will make it revert back to factory settings.In other words you have to put it in standby mode when not in use to retain recording schedule / clock time etc.
Apr 10, 2011 | Daewoo Televison & Video
The clock on our RD-XV48DT is showing the incorrect date (4th March instead of 1st March). We cannot re-set the clock manually (it just reverts to the wrong date), and we can't turn off the "clock...
i've got the same problem. looking arround the internet lots of people had the same thing last year & it corrected itself the next day. (2 march)
fingers crossed
Mar 01, 2011 | Toshiba D-R5 DVD Recorder
Everytime I remove the battery & simcard from my phone when I put it all back together again, the phone always reverts back to the date of 27/05/2009 and the time to 09h00. Surely it should keep the...
That is the default date put in there by the japs,sometimes a sick joke they use to put dec 7 in there on the old vcrs. Anyway the battery isnt holding the memory without prper voltage you wont have memory
Feb 18, 2011 | Nokia E52 Smartphone
Recording Late
Check your automatic clock setting. If it is on automatic, set it to manual, and set the date and time on the recorder. It may be picking up an unreliable time setting from a station that is not too accurate.
tom
Aug 26, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
HDD & DVD PLAYER/RECORDER / time date
Is there an option To Save Settings, after setting the time-date ?
Most devices usually have a small internal battery or memory chip that stores this information. however there are also devices that when power is removed completely. i.e a power failure or switched off at the mains, time and date settings have to be reset.
Hope this solves your problem.
Mike @ Compurepair.
Feb 22, 2008 | Televison & Video
Panasonic DMR-ES20
For the remote to work, make sure "video" is selected (instead of "tv"). It's the little button on the remote under the red button at the top that turns on the TV ("TV/Video")
As for the split screen, I've had that happen numerous times (when I lose power or revert to default settings). YOu have to go to Setup, Display, and select 4:3.
I hope I have helped you. I'm having other problems - with the audio. Some channels have no audio (maybe 3 or 4) and 2 channels are in SPANISH!!! (??) Weird that it's not uniform. I even tried reverting to default settings (and got that split screen!), but didn't help. It "jumped" a few times to the input type screen. I'm thinking some chip got fried or something. I've had it almost 2 years, and guess that's the "built-in" obsolescence!! :-)
Sep 26, 2007 | Panasonic DMR-ES20EG DVD Recorder
Cyberhome DVR 1600 DVD Recorder Logo
35 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
