No sound when using xbox
I have a Phillips Cineos TV and have just bought an xbox. The xbox cables are plugged into the side audio plugs. The picture is on channel EXT3 but the sound is on the ''Side'' channel. How do I match the two so I have sound and visual on the same channel?
  • Jorma Soininen May 11, 2010
    what is the ext on the side panel labelled
    sound and picture should go in the same set of ext inputs
  • 476 Answers
Assuming you are using the Red, Green & Blue Component inputs from the X-Box, there will be either a set of Red & White phono (RCA) inputs for EXT3 audio, or a standard 3.5mm jack socket. If so, use these. You will need an adaptor if it is a jack socket.
Dependant on model, the setup menu should have options to assign the audio input to the correct video source.
The side inputs are separate, and are only for the composite or S-video inputs.
NOTE: if you are using the component inputs, you don't connect the yellow composite input.
If this doesn't help, post the exact model number and I will be able to advise you further.
Posted on Apr 25, 2009
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
When i plug in my xbox hear sound but no picture, So i got a new xbox and still the same problem my son is crying his eyes out becuase hes has a lousy day at school and im abit angry any help?
You bought a new Xbox ,same problem.
Plug the unit in to another tv . Replace the
a/v cable , if still no picture then take it back
and get replacement.
Sep 14, 2009 | Microsoft Xbox 360 Console
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
No sound from my xbox 360
You cant have HDMI and the xomponent cables pluged in at the same time.
to get audio to your monitor you will need an xbox 360 audio adapter. You can find that here. http://www.xbox.com/en-us/hardware/x/xbox360hdmiavcable/default.htm
That comes with the HDMI and audio adapter.
You can probabaly find it seperate somewhere else.
I hope this helps.
Dec 29, 2008 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Right speaker not working
If it happens on both TVs and when you switch the cables and the other side works, then it is not the TV set and something with the Xbox or the cables going to the Xbox.
Oct 08, 2006 | Durabrand DWT2405 24" TV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
