Question about Kenmore Elite 45986 Front Load Washer
Error message "F5"?
Does anyone know what this means? I can't find my manual. Also - does anyone know who repairs this He front loading machine?
  • 5,911 Answers
F5 is a Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. If you are savvy enough to troubleshoot yourself, you can check the Water Temperature Sensor, Heating Element and Element Relay. You should also check connections to the Sensor, Heating Element and Relay. As far as servicing goes, Sears and Whirlpool have service contracts on these appliances as the Kenmore Elite and Whirlpool Duet are the same machine made by Whirlpool. I hope this helps you.
Posted on Sep 19, 2007
What does error code f5 mean?
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Read more:
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
What does F5 mean??????
To to:
First you must find your washer's model# & serial# but here is a location which contains repair manuals and views of your machine with a "code exchange" to help you determine what "F5" means. Consider purchasing a repair manual if you plan to keep the machine.
Oct 08, 2010 | Kenmore HE2 Plus Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Error Code E1
Usually when the thermistor is repaired the high limit is replaced, I dont recall the E 2 except a manual is under the console
Jun 01, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Close are Too Wet
Are you getting any type of error message on the display?
How long have you had the washer? Have you ever cleaned out the filter?
I also have a Duet (2 years old) and my clothes were not spinning out as well as they once did. I started getting a SUD error message with almost every load and then started getting a F5 message which the manual says it means it's not draining correctly. It never said how to fix it though. Went into the panel underneath washer, found the clean out plug for the was gross! Cleaned it out, washer works like new again.
Feb 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Exxcel WFX2467
try removing power from unit and re-applying about 15 minutes later
May 13, 2007 | Bosch Exxcel WFX 2467 Front Load Washer
Indiset Evolution 1200 WE125
Aug 15, 2006 | Indesit WA 125 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
588 people viewed this question
Sal De
 Brian Main
Brian Main
