Question about ViewSonic VA1930WM LCD Monitor
Dual-Monitor Color Difference
I cannot seem to get the 2 colors on these guys to match up exactly. The new one seems to have a "Brighter" white as compared to the original, with more of a "Warmer" tone white. Both are set to 6500K on the monitor's OSD and the Nvidia color settings are exactly the same for both monitors. These are (2) 19" ViewSonic VA1930wm's, however one has the model printed on the bezel of the monitor while the other doesn't. (Maybe like a v.2 type thing?). I bought both brand new, but not at the same time. There was about a 6-month time difference between when I purchased the two. If anyone has any ideas, please let me know!
  • Timothy Pearce Sep 21, 2007
    If only it was that easy =(
    [Both are set to 6500K on the monitor's OSD and the Nvidia color settings are exactly the same for both monitors.]
    Also, color settings on both monitors are exactly the same.
    Let mw know if you have any other ideas!
    I am already using the same exact driver for both.
    It isn't THAT huge of an issue, but it causes me to become fatigued very quickly (I am a music producer/recording engineer)
    Thanks anyways!
  • 68 Answers
The solution to this one is simple. Goto to the monitor that does not match and match it through the front panel settings. Also I would check to see if both are set exactly alike in the windows hardware settings.
Posted on Sep 20, 2007
  • Thomas Wesche Sep 21, 2007
    There might be another solution to this. You could be right in that it is a v2. Goto the manufactures web site. Look for support for your type of monitor. See if there are two versions out there. What i would do is download the drivers from the monitor that displays correctly to the new monitor. Sometimes a second version also means a completely new set of drivers. With Vista out there alot of hardware is being upgraded with the new 64 bit drivers.Maybe if you change the drivers to be the same as the one that is displaying correctly you will get the same results. Let me know if this works.
Phaser 8560 Colors are Off
Here are the directions for Tec Color correction. If this doesnt work then replacing the print head is the most likely solution. The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use. TekColor Description Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display. sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications. Euroscale: Matches Fogra glossy paper specification. Commercial: Approximates U.S. commercial press target. SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray From the workstation, select the color correction in a supported driver. Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS): NOTE: Some of the color corrections are grouped under Office Color or Press Match. 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed. 3. Click on the [TekColor] tab. 4. Select the required color correction. Apple Macintosh OS 9.x: 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [General], and then select [TekColor] from the pull-down menu. 3. Select the required color correction. Apple Macintosh OS X, (version 10.2 and higher): 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu. 3. Select the required color correction.
Jun 08, 2009 | Xerox Phaser 8560MFP Laser Printer
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
I have a lexmk z 82 printer, over the last 2 months the print quality of the color printing seemed to be fading i at first thought it was the staples color ink cartridge i bought but i replaced it with a...
I think its not printer or ink problem. Your monitor might be brighter so pics will look more bright on monitor and less on printer. If this is the case with you then:
  • Try to reduce brightness of your monitor, then make bright your picture using software which one you are using, means in this case you are going to save more bright value in the image file. Then print it.
Post your feed back please.
Apr 15, 2008 | Office Equipment & Supplies
Door Glass
The only solution seems to be ordering a custom glass piece matching the dimension of the glass on the oven door. However, since my oven is white I would like the door to be white too. Although I have found glass guys who can tint the glass door dark, I have not found anyone who can color it white. Let me know if anyone knows such a glass vendor.
Mar 14, 2008 | Amana AOGD2750 Gas Double Oven
Monitor gets brighter
Well... it's time for a replacement. It's seems your AD Board begin slowly to dies out... Eventually will turn to white screen.
You'll need a new AD Board.
Mar 10, 2008 | Fuji FP-768 17" Flat Panel LCD Monitor
Dual Monitor Color/Brightness Differences
Correct the resoulution is not the same. Also you are using 2 monitors and using the system to power these great displays. Just dont hook up a docking station. The picture gets really bad..
Feb 13, 2008 | Computers & Internet
Lacie 19" Electron Blue - Black screen with a brilliant white line across
I have 2 of these monitors and have this problem. I was so frustrated turning the monitor off and on until the white line disappeared that one day, I punched the screen. And it worked! So now whenever this happens (about once every other day) I use my palm and smack the lower left corner of the monitor until the white line disappears. I like the color on these screens so I don't want to replace them until I have to. I will NOT buy another Lacie though.
Sep 13, 2006 | LaCie Electron 19" CRT Monitor
Replaced LCD Screen
There 2 diffrent LVDS connectors normally on the monitor. a plat one with contacts on one side and a female connector that accepts pins on the end. I would make sure the connectors match. If that does not fix it I would change out the logic board. Check for instruction videos and parts for that unit.
Sep 01, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
ViewSonic VA1930WM LCD Monitor Logo
3,516 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
