Question about Polaroid FLM-3734B 37 in. LCD HDTV
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
  • Anonymous Apr 25, 2009
    i lost my polaroid remote and have a cable box. i am trying to change the channel on the tv manually from the side but it stays on channel 14 and now i cannot get any channels.
  • 192 Answers
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
I have removed all cable boxes from my home. I cannot get the tv remote to change channels. I was told by the cable tech that I needed to do a channel search. How do I do that?
Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here: http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
Jan 25, 2012 | Polaroid Televison & Video
My POLAROLD FLM323B is on channel 7 cannot change channel up or down by using remote or the controls on side of the screen up or down buttons
Check the websites like Shopjimmy.com,Ebay.com to buy a refurbish tv manual comtol board like Power, volume - +,channels - + menu operation functions manual control board for the replacement.The one on ur tv might be dead or u lucky probally just lose.
May 31, 2011 | Polaroid FLM-323B Television
I am looking for a remote code for a curtis 26' lcd tv so i can control it with my directv remote.
your direct tv remote has an optional code search that is useful by using the channel up and channel down buttons try to program as usual and after pressing the tv button use the channel buttons until the channel changes, when it changes hold down the mute button for a couple of seconds
Feb 18, 2011 | Televison & Video
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
May 29, 2009 | Polaroid FLM-4201 42 in. LCD Television
Channel Up/Down button quit working on the remote control
I had the same problem. You need to go into SETUP > CHANNEL > SKIP and select NO for every channel with a signal. A few months after we purchased the TV it defaulted to this (software glitch). We had lived with it for months before figuring this out. There is no easy way to reset these that I know of. I literally had to go to each channel and then change "skip" to "no." JM
May 24, 2009 | Polaroid 1911-TLXB 19 in. LCD TV
The first thing to try is to change out the batteries on the remote. If that doesn't work you could buy a universal remote and program it to work with your TV. If you have a cable box you can probably program that remote to work with your TV.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Lost remote control. need to change imput to direct tv
The input selection on Polaroid TV's is the Channel Up/Down selector. You will have to go down past channel 2 to see the input you want.
Dec 20, 2008 | Polaroid FLM-3225 32 in. LCD Television
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Polaroid remote channel button does not work
This looks to be a good hint. After reading the solution "I had the same problem. The fix is actually very easy. Just re-tune your channels in and your remote/channel buttons should work again.", I checked my remote and saw that there was a sliding button "TV/Cable" and it was on "Cable"
I moved it to TV and it started working.
This could be a dumb solution but just wanted to suggest...
Dec 06, 2007 | Televison & Video
Polaroid FLM-3734B 37 in. LCD HDTV Logo
984 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
