Question about SanDisk Sansa c200 MP3 Player
Screen is not turning on
The lights on the side are turning on but the screen is black and whenever the screen does turn on it usually freezes
  • 2 more comments
  • charres1020 Sep 19, 2007
    the lights near the screen r fine( u know the ones under the buttons) but nothing else is working
  • charres1020 Sep 21, 2007
    not really what i asked 4
    ok well, if u have anymore suggestions, plzz tell me but the whole screen won't turn on but the buttons on the right side of the device, the lights that go off under the back, front, mini menu, and menu are turning on, the blue lights
  • hell rider Nov 02, 2007
    screen is black wen i turn it on help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 626 Answers
Try connecting the device to your computer without the battery. If the device shows up under My Computer, right click on it and select format. This will delete all the music on the device. If it does not show up, you will need to call SanDisk to have a firmware file sent out. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Posted on Sep 19, 2007
  • Timothy D
    Timothy D Sep 21, 2007
    I dont know how else to interpret "the lights on the side are turning on but the screen is black and whenever the screen does turn on it usually freezes".
    Sounds like your music on the device has caused it to no longer function. Ergo, my solution will solve your problem.
    Best of Luck.
SOURCE:
I am not sure on how to wire the freeze protection wires to the time clock. i know they must go to the load side of the clock for the main pump but will this reverse the power back into controls and short...
Here's a 240V diagram with clock timer and freeze control:
Add a comment if explanation does not fit your exact timer:
See image full size:
http://waterheatertimer.org/images/Freeze-protection-500.jpg
Here's how freeze control works:
Freeze control is like regular timer, except it turns ON by thermostat instead of time-clock
Freeze control turns ON pump whenever thermostat kicks on.
Both clock-timer and freeze-control are wired to pump in 'parallel' so to speak.
Think of it as having two controls wired to same pump...
Both controls can turn pump ON-OFF.
If one turns ON, and other is OFF ... then pump is ON.
If both are ON, then pump is ON ... and electricity just flows around on extra wires.
If both are OFF, then pump is OFF.
Say it's below freezing all day.
Freeze control circuit is ON all day ... pump is ON all day
Clock timer turns ON > but circuit is already ON, so timer just opens more wires for electricity to flow around on.
When clock timer turns OFF > freeze circuit is still ON because it's below freezing ... pump is still ON.
240V wiring:
Power leads coming from circuit breaker go to terminals 1&3 on clock-timer
Same power leads connect to freeze-control-black and freeze-control-red.
Or connect freeze-control-black and freeze-control-red to terminals 1&3
This action puts power to clock and power to thermostat
Pump wires connect to terminals 2&4
Same pump wires also connect to freeze-control-blue and freeze-control-yellow.
Or connect freeze-control-blue and freeze-control-yellow to terminals 2&4
This action connects pump to both freeze-control and timer.
When either clock-timer or freeze-control turn ON, then pump turns ON.
Nov 15, 2010 | Intermatic Timer PF1222TB Multi Circuit...
IMAC SCREEN FREEZES OR GOES BLACK.
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
When I turn my computer on it loads to a black screen, then stops
Your windows is corrupted the best way is to turn off when turn on
keep pressing the "F12" button insert windows disc provided with your laptop highlight cd rom dvd rom ( or something similar ) by using down arrow on keyboard press enter follow instructions to install fresh copy
PS i once had this problem
Dec 21, 2008 | Dell Inspiron 6000 Notebook
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
Doesn't always power on
the beeps you here are bios beep they are telling whats wrong. can you count the beeps for me and give me more info on your pc
Oct 27, 2008 | HP Media Center m7260n (EG642AA) PC...
Acer Aspire screen turns black
Easy
Go to your power setting option and select never for turning the system to stand by and hibernation.
Oct 18, 2008 | Computers & Internet
!!!!!!!!Upstage Froze!!!!!!!!!
Something like this happened to me except my phone would not stop ringing an screen went all balack both sides... Try leaving your phone until the battery dies then charge it fully before turning it on it has helped me numerous times before.... reset button still works on mine it is like a miracle spot actually
Jan 11, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Westington LTV-27w7 HD black screen
ICheck the power supply connections make shure tht the plugs are seated correctly. The power supply isreplaceable as a complete uitand you have to return a repairable unit.
loumargo
Allied electronics
[email protected]
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
SanDisk Sansa  c200 MP3 Player Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
