Question about Garden
Weedwacker stalls when given power
Craftsman weedwacker tuned up with fresh gas mix, new .020 gaped plug, clean air filter and clean spark arrester screen. Starting procedure is to quickly press accelerator after warm up. It then idles. When accelerating, no matter how slowly, the engine will quit before reaching peak RPM. When new, it would accelerate properly but not idle after decelerating. It is now 11 months out of warranty.
Can someone help me?
Thank you
  • zorchrdg Apr 19, 2009
    Solution for a different problem. Not my problem.
#1 Taper
  • 1040 Answers
SOURCE: craftsman weedwacker model 358.795160 will not
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor again. Make sure the small screen in the carb. is free of debris. You should be able to see daylight through it. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Posted on Jun 14, 2009
#1 Taper
  • 1040 Answers
SOURCE: Weedwacker stalls when accelerating
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
Jim
Posted on Jun 25, 2009
digritz
  • 530 Answers
SOURCE: craftsman 32cc would not idle
If you are certain that you have correcting gaped the plug then the next step is to readjust the low end idle carburetor. If you look you should see two holes in the plastic cover that lead to the flow adjustment screws they may even be out in the open. If they are not labeled H and L (the L is the one you want), check your manual for the correct one. A good place to start is turning the screw all the way in then backing it out 1 1\2 turns. Then check it. If you still have problems do 1\4 turns out. After about one full turn from that you might want to consider taking the carburetor off and removing the float bowl or the bottom for a good cleaning. A sticking float could cause problems with your fuel flow.
Hope this helps.
Posted on Sep 03, 2009
carlsbiz
  • 1124 Answers
SOURCE: TB70ss will not accelerate
Change the spark plug..
Change the fuel filter..
Check the fuel line for crack/splits..
Make sure the primer ball is sealed and not succking in air while running..
If it still acts up - it might need the carb might need to be rebuilt..
If it sat for a long time - the fuel will shellac in the carb and provent it from working properly..
Good luck..
Posted on Sep 10, 2009
  • 100 Answers
SOURCE: 32cc Craftsman weedwacker dies at idle
could be blocked muffler
Posted on Aug 14, 2010
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
My craftsman weedwacker 27cc curved shaft wont start and cant figure it out
I need to ask. Did you leave fuel mix in it for a long time? If so then the carburetor will need to be cleaned with a special cleaner. and not the spray can stuff.
Nov 24, 2014 | Craftsman 27cc 2Cycle Full Crank Curved...
Craftsman weedwacker won't start.
If you are happy the carb is now ok and the plug gets wet with fuel, then either there is no spary ( remove the plug, place against the cyliner, away from any fuel source near the plug hole, crank the engine and see if there is a spark ) if there is a spark, then it could be a sheared flywheel key knocking the ignition timing out.
Jan 15, 2014 | Garden
My weedWacker don't star I change the spark nothingh happen
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Aug 19, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
Poulan 32cc multi-attatchment weedwacker will run with full choke. When you take choke off, it slowly dies. If you give it gas with the throttle trigger, it sounds like it's being muffled and then dies. ...
Try backing out high speed screw counter clock wise a guarter turn. Also check muffler for blockage. Spark arrester screen may be blocked. Remove screen, clean or replace. I use bernzomatic tourch to burn off deposits.
Oct 03, 2010 | Garden
Sears weedwacker won't start 358.797150
Plug could be fouled. Make sure you have fresh fuel mix.
Aug 19, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
1,918 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
