Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
Troy Bult 01902 Leaking gas from air filter area
I have a Troy Built 01902 2350psi 2.0gpm pressure washer. I have never used it but did let someone borrow it a couple of years back. It was brand new and since being returned has not been used and has been sitting in the garage. I decided to fire it up and actually use it and take advantage of it. Well when I tried to fill the gas tank I noticed that the gas just spills right out of where the air filter goes. No matter what position the choke is in it just leaks out until empty. I read somewhere it could be the float but I would like an expert opinion. If so I have not seen that part for purchase unless one has to disassemble the whole thing to get to it. If that is the case then I will drop it off for service but if this is something that I could fix it would be greatly appreciated. I know this is a consumer model but It should be fine for my needs and I do not want nor need a new unit if this can be restored to functional status.
  • Radiorara May 03, 2009
    Thanks for you help. I have not tried messing with it since this post. However I am aware about cleaning the carb and such. I really wanted specific help on the gas leakage and the float and why it could be leaking. I do not care about spark or ignition as I am not going to start it if it is leaking gas. Starting was not the problem I listed anyway therefore the solution does not fit. I appreciate your help and will do what you have stated as it could use some preventative maintenance. Thank you and God Bless!
2 Suggested Answers
  • 508 Answers
SOURCE: Troy Bilt Pressure Washer Model 01902 Leaking Gas from Air Filter
try banging lightly on carberator with block of wood or something to free up float and valve!!!!
Posted on Jul 01, 2009
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Gas leaks out side of pressure washer
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
Jul 27, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
I have a troy built pressure washer leaking gas from the air filter i looked around for advice and hurd bang against the carb and it will realease the float valve i did it and it worked but should i clean...
definetly replace the paper filter and yes Lowes will carry them.if it does not leak now, I would leave it alone or you will be installing a nine dollar kit.The briggs kit # is 294260 is you choose to do it anyway
Nov 15, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
No pressure in power washer.
usually you can get a seal kit for your pump. I would need the model number to direct you to the parts you need.
Sep 03, 2009 | Garden
Jul 01, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Have a troy built pressure washer and the gas is leaking out help
the float is stuck you can either take it apart and clean it or you might get by by just tapping lightly on the fuel bowl on the bottom of the carburator to unstick the float
Jun 20, 2009 | Garden
Bought a pressure washer 50$ no water is comming out of the gun
check the water intake, is it clogged, check all your connections are connected properly and check that there is a good flow of water coming from the output of the water valve.
hope this helps,
joey!
May 06, 2009 | Garden
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
439 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Coleman Garden Expert? Answer questions, earn points and help others
