Question about Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
It is not sucking up all the water
My hoover DualV is not sucking up all the water and my rugs are wet. When I first bought it my rugs were much drier after I shampooed them. Not much water is going into the tank. Can I fix this problem or does it need to go into repair.
Re: It is not sucking up all the water
I have this problem with my Hoover SteamVac V2 occassionally. I usually find it is caused by one of three things. The dirty water tank is not locked down well, the hand attachment flap has not been pushed in all the way to seal tightly, or the suction area is clogged up. The first two are easy to check. To clean the suction area, I use a Zip-it which is made for drain cleaning but fits in that area perfectly. It available at Lowe's or on the web.
Posted on Feb 10, 2008
I've had this happen to my SteamVac V2 and usually find that it's because I don't have the dirty water tank locked down well or I haven't pushed the hand attachment flap in tight or its gotten clogged up down in the suction area. I have a black lab and that area accumulates dog hair quickly. I use a Zip-it available at Lowe's or on the web to clean that out.
0 characters
3 Points
Why isn't water getting sucked up?
the sucker cleaner thing is broken, buy a new Dry Vacuum
Mar 26, 2016 | Hoover H3060 FloorMate SpinScrub 800...
Suck hoover
If the wire is underneath the unit it won\'t suck up the water. I did this once. Make sure it is flush with the floor.
Nov 11, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
Will not dry or suck up water at all...BRAND NEW
If it's brand new your best bet might be taking it to a Hoover service center. That'll have a year warranty on it so the fix would be free.
Apr 06, 2013 | Hoover H3044 FloorMate SpinScrub Wide-Path...
I just washed my rug, how do I get extra water up?
I would recommend using a shop/ wet vac to do that. It's made for sucking up a lot of water from carpet.
Feb 19, 2011 | Kirby G4 Bagged Upright Vacuum
Instruction manual for hoover swish carpet cleaner
my hoover swish dosent seem to **** up much of the water out of the carpet carpet is still quite wet and bot much water is sucked up for the amount of water that goes in the water dispenser
Nov 26, 2010 | Vacuums
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
Sudsy water leaking from bottom of machine. Also it is not sucking the water out of the rug properly. Any ideas???
sounds like the same problem i am having you may need a new clean tank here is the manual for your machine
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover F7205900 SteamVac V2 Wet/Dry Vacuum Logo
149 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
