Windows Vista Home Premium will not connect to the internet
Itry to connect to my work's wireless router and I get only local connection I'trid every thing I coud think of! I could connect before I upgraded from Vista home Basic about a week ago, any help would be great.
Thank's in advance!!
Steve
Acer aspire 7520 cant connect to LAN ( local only)
Hardwired to modem or router?
Router = check connection to router
(had a router die on me last fall - not AC supply)
IP should be 192.168.1.xx or 192.168.2.xx
(is standard)
Reset Router = reset hole on back - hold for 10 sec
Modem= same directions as router
(most modems work like single port routers)
(do reset of cable modem, I've had that prob too)
Using PPOE connection = check log on info
Took most of my home network apart to find it was the modem causing the problem - should've started there.
Apr 04, 2010 | Acer Aspire 7520-5185 Laptop
Actiontec GT704WG doesnt connect to internet
HI! all your computer is connected except for one, you are connected to to the local network but cant get an internet connection, I dont see any problem with your wireless connection bcoz you are connected to the lan, check the security settings of your browser on your windows vista, go to internet option and security, lower it down to medium security, so that you can access the internet or try using other browser like firefox or google chrome.. check your firewall settings as well on your windows vista..
Aug 08, 2009 | Actiontec GT704WG Wireless Router...
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Unable to connect to the internet at times.
Problem #1:
Please give more details about your setup -
  • What kind of router are you using (make. model, version)?
  • Do you have a wired or wireless connection from your computer to your router?
  • By "resetting" do you mean to "repair" the connection via the taskbar?
Problem#2:
This is apparently a well-known bug in Vista, but nothing to worry about. Take a look at the information from Microsoft.
Please give more details regarding problem #1 and I'm happy to see if I can be of any help.
Jun 10, 2009 | Computers & Internet
Using Vista Home Premium on Firefox, goes off line at times
Are you on a wireless connection or a wired connection? If you are on wireless, try changing the channel on your wireless router. You may be getting interference from another source/network.
If its a wired connection they try right clicking the connection and choosing "repair." This will correct several basic network problems. If that doesn't fix it, post back and further troubleshooting will be required.
Jun 03, 2009 | Microsoft Windows Vista Home Premium...
Getting Vista to use my wireless internet connection correctly
One question, is... do you need to enter a KEY or is this an open network?
I have found that with a new computer, you need to do the following to connect.
If this is an open network, then leave your router running, and just do a cold boot with your computer.
IE: Shut down, count to 10, and then re-start.
You may also need to connect (by network cable) to your router and make sure the wireless is turned on.
Most new rountes start with the wireless disabled.
Jan 01, 2009 | Microsoft Windows Vista Home Premium with...
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
