Question about Nintendo DS Lite Console
Time and date
My nintendo ds seems to have reset the time and date to 2005. the manual says to change this by entering the settings menu but the console wont let me access te settings menu. i have tried with and without a gamepack inserted, nothing else in the manual. plz help!
  • Anonymous Nov 27, 2007
    ds lite won't keep correct date or time.
    Novelist:
  • Nintendo Expert
  • 127 Answers
While the unit is OFF, push down and hold the START button then turn ON the NDS. You can try the same with the SELECT or both buttons down.That must grant you access to the DS main menu.
By default the DS load the game cartridge when only one slot is used and let you choose when two slots are used. So if both slots are empty the menu must appear though your case would be very rare.
Good Luck...
Posted on Oct 17, 2007
SOURCE:
MASTERKEY FOR NITENDO DS
Try this my friend :
Go to parental controls in system settings. When it asks 'Change Parental Controls settings?' tap yes. When it brings up a numeric keypad, tap the center button, "I Forgot". Next, tap "I Forgot" again. Now you will be shown a screen with a number at the bottom (the 'inquiry number'). Go to wii.marcansoft.com/parental.psp on your computer and enter this number in the field marked confirmation number. Set the current date in your timezone and click get reset code.
It does work for the Ds! You just have to choose the correct time zone after you enter the code!
The master key is different for every DS system. Call Nintendo and get to the DS helper. Then you tell them your inquiry number and they will tell you the master key. You must provide proof of ID, your inquiry number on the DS and your DS serial number.
1. Click "I forgot" twice.
2. Copy the inquiry code onto the bar required on the site provided.
3. Select your date.
4. Get your master key pass.
Go to settings and flip through the options till you see ''Parental Controls''
To know the master key for the Nintendo DS (presumably because you had forgotten your parental control key) call the number 1-800-255-3700 and follow the menus on the phone until you can talk to customer service about Nintendo ds.
I hope his helps otherwise contact Nintendo Directly for support, The telephone number's for all Nintendo Offices worldwide are in the user's manual if not you can Google them.
Jan 14, 2013 | Video Game Consoles & Games
How to set the date of ds
you go to the lttle nintendo sign when you turn your nintendo on and go todate time and alarm settings and change the date there
Oct 01, 2012 | Nintendo DS Lite Console
Hello I have a upgrade R4 but i cannot get on to the menu.As i get it on with the cartridge,it says - System date error! Please check NDS system date.I keep on checking,but nothing seems to work.
Go into your DS time and date settings and put the date back a few weeks. This will solve the problem temporarily until a new kernel update is brought out for the R4 card.
Hope this helps
Aug 05, 2010 | Nintendo DS Lite Console
Ds lite clock stopped :(
you need to reset it. mine stopped to and that worked. if it doesn't email me @ [email protected]
Sep 16, 2009 | Nintendo DS Lite Console
DS lite only playing one type of game
Reset Factory Settings for Nintendo DS 1. Use a small screwdriver to unscrew the back cover.
2. Remove the battery.
3. Wait a few seconds.
4. Replace battery.
5. Turn on DS.
6a. If you have to re-enter your nick-name/time and date etc, it has worked! Go to 7.
6b. If not, remove the battery again and wait longer.
7. Replace cover and screw back in place.
Jul 31, 2009 | Nintendo DS Lite Console
My nds is stuck in the same time, help please
I would first try to reset the ds to factory settings.
4. Replace battery.
5. Turn on DS.
I've heard of this happening before but usually intentionally done in order to manipulate time in games that make use of real world time change.
Jul 03, 2009 | Nintendo DS Console
Date settings gone
Is it a ds or a ds lite?
Turn on the unit with no cartidges. Press the screen to acknowledge the warning message.
On the next screen, press the tiny ds icon at the center bottom of the lower screen. This enters the setup. Fromhere you can press the clock calender icon (blue one) to set the time. Youcan also change other settingswith the other icons.
Sep 07, 2008 | Nintendo DS Console
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Nintendo ds lite time and date freezing
Call a nintendo help line or exchange it where you purchased the ds and get a new 1 for free.
Dec 28, 2007 | Nintendo DS Lite Console
Animal Crossing game date has changed to a new date in the future with all previous game details changed.
It is most likely a fault in the circuit board or a software virus caused in manufacture.
Apr 18, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
112 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
