Question about Dryers
Power supply question
My Maytag DE7600 electric dryer, is it 220 or 110v? It has a large three prong 220 looking plug, but it says 110/220???
  • Lamb_H Apr 20, 2009
    My DE7600 has a three screw block behind the small palte on the back. Can it be transferred to 110 volt?
    Genius:
  • 1,122 Answers
It is 220v, 110v on each leg, does the terminal block on the back of the dryer behind the small cover have three screws?mike
Posted on Apr 19, 2009
  • MIKE major Apr 20, 2009
    no,if it has a three screw terminal it's made for 220v-mike
Maytag Neptune dryer went from 4 prong to 3 prong...cabinet light works but dryer we won't star
It's not wired right. You're only getting 110 vac to the machine which is why you are seeing some lights but no operation. Make sure when you went to the three prong plug you connected to both 110 vac lugs and common.
Feb 17, 2014 | Dryers
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
Need to know the correct 3 prong power supply cord to use for a Maytag Atlantis dryer.
Hi fredmcmur227...
There are many different pattern plugs and recepticals.
It is impossible to tell you which power cord to buy.
What you will need to do is find out what the receptical for the dryer looks like and match the receptical with the power plug your going to purchase.
I will also include a link to show you how to hook up a 3 prong wire power plug.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jul 11, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Is kenmore 98702 220?? or 110???
if it has a small 3 prong plug then it's 110v for the washer but the dryer should be factory 220 volt however many were sold wired too! 110 volt! just look at the plug small plug 110v large 3 prong! 220v
Jan 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
Can you tell me how to hookup the three wires of 3 prong cord to the back of dryer that came with 4 wires(4 prong)? Which one goes where? I only have 3 prong plugs at my house. Thank you.
The following link explains how to connect a power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Now keep in mind, some newer appliances REQUIRE a 4-prong plug in order to work properly. You may consider having a four-prong outlet installed to accomodate your dryer.
You can try these steps by referring to to section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, please let me know. I hope this helps you.
Jul 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag drier de7600 connected new power cable to the 3 prong terminal on back of drier ground wire to the middle prong and the other wires to first and last. Drier does not start. What's wrong
check the breaker and make sure youturn it all the way off and all the way on. if you have a volt meter check the voltage from the two outside legs you should have 220volts
May 28, 2009 | Dryers
Switching electrical plugs
it sounds as if your plug configuration is for 220 volts. that means that all wires are needed to operate the unit. white is the common and red and black are both power leads. in other words...the red lead provides 110 volts and the black provides 110 volts, and the white is the common for both circuits. and of course the ground is for curcuit safety
to change to a three prong plug the ground must be sacrificed but with shock risk. i suggest a seperate ground wire run to an adequate ground.
a typical three prong plug will mean that the two prongs closest to the edges are the two power leads and will use the red wire on one and black wire on the other.(doesn't matter which one goes on which prong)
the white will go to the center or usually odd shaped prong. be sure and be safe!
hope this helps.......................jay
Mar 20, 2009 | Bosch Nexxt 800 Dryer
Open Questions:
Dryers Logo
96 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
