Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
My bearcat wont trans or recieve what could the problem be
Arctic cat 454 bearcat rear end stopped pulling. Why?
check chain and trans will need to remove side cover to check belt and clutch
Jul 03, 2018 | ATVs
I have a Uniden Bearcat "BC 855 XLT" scanner. It scans properly, the antenna is good and the solder connection is good. Yet is will not recieve a signal even the weather. What part needs to be replaced?
There's no telling without completely troubleshooting the unit, and that would likely cost you more than the unit is worth. Used BC855XLT scanners are selling for between $15 and $30 on eBay . . . .
Bill B
Listening in since the 60's
Oct 11, 2010 | Radio Communications
Wat is a code p 1698
p169 is "no ccd bus mesages recieved" that means the engine OR trans computer has not seen any communication (called a BUS) from the other modules on the communication bus if the instrument cluster is not working then it is the source of the code if the car wont shift then there is a communication issue with the trans computer if it wont start then there is a problem with the engine computer communication this is usually set by a bad instrument cluster
May 18, 2010 | 1998 Dodge Caravan
I'M TRYING TO WIRE A SUPERSTAR DM-452. i NEED TO KNOW WHAT EACH COLOR OF WIRE IS. EXAMPLE RED- AUDIO, BLUE- TX ETC....
The wire colors are as follows
1.shield 2.white 3.red #4.black The pin numbers are located on the end of your mic plug
1.shield 2.audio 3.transmit 4.recieve
Mar 05, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
How to program a bc 560xlt bearcat scanner. Thanks, Les. lorlick@yahoo.com
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
Aug 24, 2009 | Office Equipment & Supplies
Can I upgrade to recieve marks system.
If you mean the State of Ohio MARCS system, then you need a digital trunking scanner. The Radio Shack Pro-96 and PRO-2096 will work as will the new GRE 500/600 units and a couple of Uniden Bearcats. They must say "Digital Trunking" or "P-25" for it to work on Ohio MARCS.
Aug 04, 2009 | Uniden BC248CLT Base Scanner
Uniden bearcat bc60xlt-1 channels wont unlock
Channels have to be programmed with a frequency before the scanner will allow them to be unlocked. The L/O indicator should automatically turn off once a frequency is in memory.
Mar 17, 2009 | Uniden BC60XLT Handheld Scanner
Mic not Keying up
Sounds like you are not modulating well. try adjusting your amp.also, test your antenna for wire breakage and, make sure that your mic has good wires as well.
Jan 22, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Unable to quit the squelch
This is an internal problem that can only be repaired by a technician familiar with Bearcat scanners. If you live near NJ, call 973-831-5900.
Dec 24, 2008 | Uniden BC248CLT Base Scanner
I can recieve but i cannot transmit
sounds like you might have a bad voltage regulator
Apr 03, 2008 | Uniden Bearcat Pro PC68LTW 40-Channels...
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
42 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
