Question about Kenmore 47732 / 47734 / 47739 Electric Double Oven
Kenmore double oven won't run on
Model # 911.47642100. I've had several episodes of F7 where we take the ribbon off and clean it or shake things around a little but recently we had a new symptom. The oven will turn and get to temp for some random period of time, then turn off on it's own. It's done that for about 2 weeks and now it just won't turn on. The clock works so it's getting electricity. I'm in the middle of wiggling and re-seating all the plugs in the circuitboard but if anyone has other suggestions I'd love to hear them. Thanks.
  • jkennedy_4 Sep 30, 2007
    You are The Man! I have the plastic keypad with the dual ribbon and slid the paper in between the two. At first it made no difference so I pushed it further down the slot and it's been working for two days now!
    You just saved me ~$400 in service calls and part chasing. Thank you!
You are The Man! I have the plastic keypad with the dual ribbon and slid the paper in between the two. At first it made no difference so I pushed it further down the slot and it's been working for two days now! You just saved me ~$400 in service calls and part chasing. Thank you!
Posted on Sep 30, 2007
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
Go to the following link for my fix to the F7 problem. I have helped over 1300 folks with the same symptoms. http://fp1.century.net/Powerman/ Dreaded%20F7%20Problem.pdf Enter all that on one line. Clicking on it won't work. If you can't get to my webpage, email me at hutchipop@yahoo.com and I will send you my instructions. Good Luck, Charlie Popeck, P.E. Consulting Engineer
Posted on Sep 19, 2007
Kenmore oven has error code F7
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem.
Jun 13, 2010 | Kenmore 41389 Electric Double Oven
Oven shows an error code of "F7"
Try this first! The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem.. Good luck!!!
Oct 21, 2009 | Kenmore 41392 / 41394 / 41399 Electric...
My Kennmore double oven is beeping with an F7 code
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Jul 28, 2009 | Kenmore Ovens
F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Jun 30, 2009 | GE JTP45 Electric Double Oven
Error code f7 on Kenmore wall oven 911.41165791
May 27, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
Kenmore double-oven (electric)
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Sep 22, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
Double oven
ovenman, there's not a complete model number here but in the Kenmore line F7 is the code for a stuck function switch or bad keypad. Makes sense that it's telling you to start the lower oven. Try removing the ribbon cable from the board and cleaning the ends with an eraser. Reseat it and see if the code comes back. Make sure to kill the power before doing this. Catriver..post back.
Mar 28, 2007 | Kenmore 47732 / 47734 / 47739 Electric...
Kenmore 47732 / 47734 / 47739 Electric Double Oven Logo
202 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
