Lost my picture on my toshiba sateille laptop added memory. put battery back in and tryed to start it and had no picture on screen ?
  • travishanson Apr 28, 2009
    I am using a Kingston 2 gb PC2-5300. I have to rplace one of the old ones as there is no extra memory bay. I've gone online and viewed compatible laptops for this particular item and it says that they are compatible. Unfortunately I'm running into the same problem as srr58 is.
  • 155 Answers
Remove the memory module you added. Maybe it is incompatible with the laptop or is damaged.
Posted on Apr 19, 2009
I have a Toshiba Sateille L505 and I have no sound and my usb doesnt work. There is a red x overmy speaker at the bottom of screen.A nd it says no audio ouyut device is installed. What do i do?
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Aug 22, 2014 | Toshiba Satellite Computers & Internet
Toshiba sateille A105 s2141 black screen at start up
check the laptop using an external monitor and if there is no display then the mother board is faulty and will need the help from a service center.
If there is display then it is confirmed that the LCD panel is faulty. It can be due to faulty LCD, linking cord to the panel or an interface failure of the display section.
All of the above will require that you must have some test equipments to confirm.
Aug 11, 2011 | Toshiba Satellite A105-S2031 Notebook
Cant find cmos battery on toshiba satelite l300 motherboard, need to reset hdd password
You cannot reset a HDD password (if its a bitlocker one) and you have lost your encryption key reset file and forgot password.
if you mean the BIOS/Power on password then try this
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 10, 2011 | Toshiba Satellite Pro L300 Notebook
WHEN I TURN MY PC ON THE SCREEN CANT START UP ITS DARK AND I WANNA KNOW THE PROBLEM AND THE COST OF THIS
try to remove the battery then connect the power an try to on the laptop if it works then shutdown the laptop an reconnect the battery then on,if not then if possible remove the memory from back portion by removing the screw then clean the memory an put it back if not sorted the u have to take it to a Toshiba service center ,the cost for the system board may be some ten to twelve thousand rupees
thanks for the query happy to help you fixya team
Dec 21, 2010 | Toshiba Satellite L305-S5911 Notebook PC
Toshiba Satellite - black screen only when plugged in
hi
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTUNUE TO USE YOUR LAPTOP
Jul 07, 2010 | Toshiba Computers & Internet
I have a toshiba laptop about three years old Wont start up right
The problem there may be your cmos battery or possibly a memory issues. If you just recently added memory, I suggest you find a more compatible one for your laptop.
Feb 06, 2010 | Toshiba Satellite A215-S4747 Notebook
Upgrade memory problems
are you sure you are putting the proper ram in? don't mix and match speed and size. If you can put it back the way it was and get it to start again, go to www.crucial.com and run the scanner. It will tell you exactly what you need.
Jun 16, 2009 | Toshiba Satellite A60 Notebook
Won't boot up past the Toshiba screen
Unplug any external devices. Remove additional memory if added. Take out battery and unplug ac adaptor. Press power button and hold for 20 seconds. Plug it back into the mains and try to turn on again. If this will not work replace mainboard.
May 26, 2009 | Toshiba Satellite Laptop with AMD Turion...
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
