SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
SOURCE: washing machine is leaking from the bottom
Check under the front corner of the machine - I had the same problem with mine, which was damaged during delivery. Mine had a part broken on the water pump - where the emergency drain hose attaches to the water pump the little plastic connector had broken off.
I have just done what ozimpact suggested and the drum is moving back and forth as it should be.
