Question about Electrical Supplies
Have a generac 00802-2 in my rv that would start for a few moments and die. Now it won't start at all and it is getting power to the cylinoid? What could this be?
  • 3 more comments
  • rdastrup Apr 19, 2009
    Is there a way to troubleshoot without pulling the entire generator out of the RV? Can you tell me where the low oil sensor is located on this particular unit?
    I replaced the fuse and it starts but it is still dying
  • rdastrup Apr 20, 2009
    Where is the capacitor located on the generator?
    Also, how do you discharge the capacitor?
  • Noel Coward
    Noel Coward May 11, 2010
    Will it still Crank even though it will not start?
  • 355 Answers
This sounds a little like a bad wiring problem between the transfer switch and the generator. But before I leap to any unfounded conclusions let's make sure I understand just which Guardian generator and transfer switch you have. The generator I think you have is an air conditioner sized box that has a 2 cyl air cooled Generac GT990 engine in it. The control panel has a 15 amp fuse, and maybe a 7 amp one, some LED indicators, a 3 position rocker switch (manual,off,auto), and a momentary set exercise switch. If you look inside your transfer switch there is the transfer mechanism, a single relay, either 2 or 4 fuses, and a terminal board where 4 small control wires connect to the generator. The control wires will be labeled N1, N2, 193, and 23.
If all of that is true then I'll also assume that the generator is blinking all of the LEDs and as soon as you put the rocker switch in the manual position the generator starts and the transfer switch moves to the "generator" position. It shouldn't do that, manual means switch the switch manually too. :-)
Let's take care of the exercise setting first. Switch the main output breaker of the generator to the "off" position, this prevents the transfer switch from activating even if the generator runs. Next put the generators rocker switch into the "Auto" position and wait at least 1 minute, if the generator starts we have to fix the wiring between the N1 and N2 terminals in the transfer switch and the matching terminals in the generator before we can proceede. If luck was with us and the generator is just blinking its LEDs at you, press and hold the set exercise switch for 30 seconds, you're reseting a "watchdog" type circut so it has to be for the whole 30 seconds. When you let go of the set exercise switch the LEDs should blink another 10 times or so, then the generator should start and run its exercise for 12 minutes more or less and then it'll shut down. At that time the only LED that should be lit is the green "system ready" one and it should be steadily lit. Remember to close the output breaker again.
Next let's address the transfer switch issue. If I've understood you correctly, the transfer switch moves anytime you turn the generator on. The only reason a regular old RTS type transfer switch could do this is that it's being commanded to transfer. It works like this, the 2 coils that move the transfer mechanism get powered by the source we're trying to switch to, once the switch gets into the position it's going a pair of limit switches disconnect it from the power supply so that the coil is only "live" during a transition. Spring loaded contacts hold the switch in either position once it's more than halfway towards either one. The relay inside the box is also in line with the limit switches so that if the relay is deenergised the switch will try to get to the utility position and stay there, it can't if there is no utility power to drive the transfer coil. On the other hand if the relay is energised, the switch will try to get to the generator position and stay there, if there is no power from the generator it can't because the generator is what drives that bottom transfer coil. So I think that for whatever reason the relay in your transfer switch is staying energized when we don't want it to be.
On the terminal board inside the transfer switch you should see terminals labeled 194 and 23, these are the power to the relay coil (194), and the ground to transfer signal (23). With the generator set to off, and a fairly quiet room, disconnect the wire from terminal 23, if you can hear the relay coil click on and off when you touch the wire to terminal 23 there is something wrong with the wiring at the generator end of things. You should also see 12 volts DC between terminal 194 and ground, this comes from the generator too.
If the relay didn't click back and forth above check it by using a short piece of wire to connect terminal 23 to ground, if the relay isn't energised when terminal 23 is grounded and deenergized when terminal 23 is open you either have a bad relay or a problem in the grounding of your system. To get a bad relay fixed for free call up Guardian, register the generator (you'll need proof of purchase), and get them to tell you where your nearest warrenty service person is. If you tell him about this post he'll bring a relay with him when he comes to you.
If you're satisfied that the relay in the switch is working properly, we're on the trail of a wiring problem at the generator end of things. If the generator has just been installed you should carefully check that wire 23 hasn't been connected to terminal 0 at the generator terminal block. It's easy to get this connection wrong when doing th e install. The other thing that can go wrong is that the wire can get pinched inside the conduit and short to ground. To check this disconnect both ends of wire 23 and measure between either one and ground, you should get nearly infinite resistance.
If you've proved to yourself that all of the wiring is correct, and the generator is properly grounded, you probably have a broken control board in the generator. To get the control board replaced use the same procedure as the relay above.
If that doesn't get this resolved for you post a comment and we'll try a different approach.
Posted on May 18, 2009
  • Rohit  Asthana
    Rohit Asthana May 18, 2009
    Check the spark at the plug,compression and carburation.Priming the
    engine,putb some gas in the cilinder and start the engine.If the engine
    runs only the gas you puted in the cilinder you have a delivery problem
    to find and fix.Remove the carb,disassembly and clean it,check and
    clean the air and gas filters.
  • 527 Answers
Sir,
Check these links and go through the site to solve the problem
Link 1
Link 2
link 3
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Apr 20, 2009
  • 19,396 Answers
Check the motor capacitor , when you get this problem usually is the capacitor. If you want to test the capacitor , remember to allow discharge, otherwise you will get electrocuted even when the generator is off, as the cap. holds big charge. Otherwise just replace the capacitor.
You find all parts here.
  • 854 Answers
- please check of you have burnt smell near the motor, If it has, then the motor should be rewinded or carbons contacts should be replaced
- check the integrity of the starting capacitors (this capacitor is usually located near the motor itself)
- check the connectivity of the power lines.
Hope this helps...
Posted on Apr 19, 2009
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
I have a generac mc alternator model -38 6938 my voltage pulsates underamload just started any ideas
Cleaned and adjust carburetor per Repair Manual. then adjust governor repair manual and should take care of problem on this old generator.
https://www.generator-parts.com/manuals/generac-rv/051834.pdf
Jan 07, 2015 | Generac Electrical Supplies
Generac generator manual
Usually generators that have stood for a very long time loose the magnetism in the ignitor coil magnet. With care, if you can find the low voltage wire into the generator 'motor' you can apply a 9v battery briefly to it and spark it into life. Use the generator if you get it generating, for a good period and don't leave it unused for a long while.
*IF YOU DONT KNOW AND UNDERSTAND ELECTRICITY DO NOT TRY THIS. GENERATORS CAN KILL*
Jul 31, 2014 | Generac Power Systems Generac 0057500 75...
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5754 4.8 kW 120/240 Volt PrimePact...
It back fires
If it backfires, check for manifold leaks, fuel mixture is too lean, timing is off, make sure it isn't spitting liquid into the cylinders and the LP is the right pressure, and the vapour coil is working
Oct 05, 2013 | Generac Guardian RV Generac RV Generator -...
2008 Gaurdian Generac 3cyl diesel shuts off after hitting bump
If you dont find a solution here. Call Generac in Waukesha WI. and get the number for Robert Schwalm Co. He is the best in the Country for Generac I used to be #2 but I havent worked on all the new Generacs. Give me an old RV unit and no one is faster!
May 20, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
148 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
