I have downloaded obscure pc to my laptop..windows xp....got all five disc to load: now its asking for a disc key code. I dont have the original box which the game came in, nor did i register the game. Is there any way i could get a disc key code for this game.thanks
SOURCE: windows xp
The hard drive may be defective. It is very difficult to fix a computer problem over email unless it is a common type of fault. Get a computer tech to check this out for you.
Jerry G.
SOURCE: windows xp activation code
How to Activate Windows XP in 5 Minutes or Less
Having rebuilt, tested, and reloaded hundreds of computers, I’ve become keenly aware of one of the unavoidable speedbumps during setup — Windows XP’s product activation. After one too many activations, Windows complains that your product key is no longer valid or you’ve exceeded the limit. To keep Windows on the up-and-up (and stay atop the seemingly endless flood of security patches), you’ll have to activate once more with Microsoft. Here are some time-tested tips that will get you through the mandatory process in five minutes or less.
Try Internet Activation First
If you have an internet connection when activating Windows, attempt to use the online route first. In the Windows Product Activation Wizard, choose “Yes, lets activate Windows over the internet now”, followed by “No, do not register with Microsoft”. You may receive a friendly “Thank you!” and your copy of Windows will be good to go.
If internet activation fails and the Wizard complains about “too many activations” or an “incorrect product key”, you still have the option of calling Microsoft’s toll free number to activate Windows. As long as the Wizard doesn’t report “invalid product key,” options are still open. An “invalid” (not “incorrect,” mind you) key is one reported or detected as pirated, so you’ll have to find some other way to make your software go.
Phone Activation
Activating Windows via phone is about as enjoyable as a trip to the dentist, but knowing exactly which buttons to push and the right words to say can help cut your time in half and get you the necessary code.
If your online activation from above failed, click the Telephone button to generate an Installation ID, which you’ll read off to a customer service representative shortly. Call the number for your appropriate country, and you’ll enter into a phone menu system which would like nothing more than for you to activate by reading the numbers onscreen. The software behind the menu, however, does the same checking as the online activation method — meaning if your online activation failed, so too will the automated phone activation. Press 0 on the phone keypad when asked if you are calling to activate Windows XP (the first opportunity you are prompted for input). Like many newer phone menus, it will respond “I see that you’d like to transfer to a customer service representative”, and subsequently try to convince you to go back to the automated system. Ignore the pre-recorded woman’s somewhat rude request to go back, and press 1 to to talk to a human.
After a short delay and the distinct possibility of listening to some poorly chosen music, a representative will ask for either the first six digits of your Installation ID, or the full set. (The first six digits of the Installation ID are the only real keys to generating a Confirmation ID, however the reps more often than not ask you to read off the rest of the group. The rest of the numbers are encoded values detailing some very basic hardware details about your computer.)
If asked “Is this the first time you’re activating Windows?”, say yes. If you say no, the representative will ask for an explanation as to why you’re re-activating Windows.
If asked “Did you purchase the software from a retail store?”, say “It came pre-installed with my computer.”
As a final time-kill (their system sometimes takes a minute to generate Confirmation IDs on days with a particularly heavy load), you may be asked for your Product Key (Windows serial number).
After you’ve given them the necessary information, the representative will read the Confirmation ID to you, which you can simply type into the provided fields. Using these methods, it takes about 4 minutes to activate Windows on average.
SOURCE: Can you help? Have
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
SOURCE: do I need windows xp disc to reinstall?
To format your hard-drive then re-install Windows? Yes, you would need one.
If you're attempting to rid yourself of a virus, you can definitely attempt a system restore. However, most modern viruses are smart, and the first thing they will do is integrate themselves into the system restore files. If however you have a system-restore disk (CD-ROM) which came with the computer, those will obviously not be infected (nor will they be infected) and can be used to restore the system to the state it was in when you first turned it on.
Let me know if I can help you further.
SOURCE: error loading o.s windows xp
If you want to try booting from safe mode, start the machine and press F8 until you get a boot menu, but you getting the 'Error Loading OS' message sort of suggests your relative may have wiped the harddrive before handing the machine off to you, which would mean there will be nothing there to recover from.
Sounds as if the PC is set to boot from the harddrive, so your easiest fix would be to get into the bios settings at startup and set your 'boot order' to read from your optical drive (cd or DVD) first- Put YOUR copy of XP in and away you go!
Another option would be to go to bootdisks,com and download a Win'98 boot floppy image with CD-Rom drivers, & unzip the image to a 3.5 floppy, but that's the long way around.
You can download the drivers from the Compaq/HP WEB
support/download page. Make sure you select your model laptop and the XP or
Vista Windows version of the drivers you require and install them. Click on
this link to download the drivers: -
www.compaq.com/country/cpq_support.html
