How to change ink roller on Sharp Calculator EL-1611H
  • glazer832 Apr 19, 2009
    Thanks very much - worked perfectly
  • 1,959 Answers
1) Turn the power off.
2) Remove the printer cover.
3) Remove the ink roller by turning it counterclockwise and
pulling it upward.
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place.
5) Put back the printer cover.
Posted on Apr 19, 2009
I have a Sharp EL-1801P that is low on ink. Can I add ink to the roller or do I need to buy a new roller?
Ink roller: Type EA-772R
WARNING: APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER.
1) Set the power switch to OFF.
2) Remove the printer cover. (Fig. 1)
3) Hold the top of the ink roller and remove the roller by pulling
it toward you and then upward. (Fig. 2)
4) Install the new ink roller in the correct position. Make sure
that the roller is securely in place. (Fig. 3)
Feb 08, 2011 | Sharp EL-1801P Calculator
Can you change the ribbon
Yes you can. That type of calculator has two separate ink rollers, one black & one red. They are easy to remove by putting your finger around the little ink roller & sliding it out towards you, the new one will lightly click into place. You can buy the sharp brand of ink rollers or a generic brand that will fit your calculator.
Jan 25, 2011 | Sharp EL-1701C Calculator
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
Need a replacement ink roller replacement for Sharp Calculator EL-1801P What number
Part# IR40T
http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Thanks
Jul 12, 2010 | Sharp EL-1801P Calculator
I cant find where the ink cartridge is on the sharp EL-180P
Not familiar with your model but others I have serviced used an ink-impregnated roller rather than a ribbon; you may be looking for the wrong object. They were generally rolling directly on numeral roller.
Apr 15, 2010 | Sharp EL-1801C Calculator
How to replace ink roll for sharp calculator EL-1801c
Here is the manual on link below on page 5 tells you how to replace.
http://dl.owneriq.net/e/ea19126b-3714-4b3d-bce5-712458b60c6d.pdf
Good luck and please rate 4 thumbs for the free answer
Mar 12, 2010 | Sharp EL-1801C Calculator
Where can I purchase a ink roller replacement for my Sharp EL-1750P III calculator?
part# IR40T
EL-1750PIII http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Oct 21, 2009 | Sharp EL-1750PIII Calculator
How do you replace the ink on a Sharp EL-1192G calculator?
This diagram should help you with replacing the ink roller.
Sep 03, 2009 | Sharp EL-1192G Calculator
What ribbon does the sharp 1801p use?
It uses SHARP Ink roller Type EA-772R.
You may find compatible ink rollers with different other references from other makers.
If you want to download the operation manual for your digital printer calculator, click here:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000003765.pdf
Jul 29, 2009 | Sharp EL-1801P Calculator
308 people viewed this question
k24674
