SOURCE: Charge problem!
It's one of two things, the more likely of the two is that that battery is totaly shot, laptop battery's are usually only good for 1.5 years then loose there ability to retain a charge. It sounds like that one's just done. Unfortunatly that those batterys cost more than there worth, 100 bucks or more. The second possibility is the power cord, is that the original power cord for that? Or was on that was bought aftermaket, some aftermarket chargers will only power your laptop and not charge. Also remove the battery and check for corrison. You can build your own battery fot a a laptop if got a few hours time, and are good with a soldering gun. You get the litium ion cells you need for about 40 bucks. Follow the below link for a step by step on how to build your own battery http://www.metacafe.com/watch/479447/laptop_battery_hack_youll_save/
SOURCE: Charging problem!
Hi, No other possibility, weak or dying battery, replacement therefore is needed. Good luck and kind regards.
SOURCE: POWER DEAD using different adapter(universal) after 2 days.
Sounds like you killed the motherboard. Find a local repair shop or someone on craigslist who will diagnose it for free. Wait while they do it, should only take 5-10 minutes to confirm your worst fears.
SOURCE: my acer 3680 laptop will not power up with or
Do you get a power light when its plugged in? If not its likely the power adapter is bad and thats why it doesn't work on battery...never got charged.
SOURCE: My daughters Acer wont charge so the battery is
What happened to my acer aspire is that the charging port was not soldered onto the motherboard properly cause it to not charge. If it's under warrant they should fix it but it will wipe the computer..
