Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Water supply lead to ice maker in back of the refrigerator is leaking
The water lead that connects to the ice maker in the back of the refrigerator has come off. Water all over the floor, etc.....suspect it may have been because we didn't change the filter. Anyway, having a hard time getting it to stay put when I push it back into the opening and reset the clamp. Any ideas? I did replace the water filter and have run some water through it by using the filtered water button inside the refrigerator. Thanks for your help and ideas!
  • jlssaun Apr 19, 2009
    I didn't see anything that was bent or crimped. Does this picture help at all? I was able to get it reinserted but it leaks. Thanks for the help.
    Scholar:
  • 126 Answers
If the end of hose is bent or crimped it needs to be trimmed off in order to install properly
Posted on Apr 19, 2009
Water leaking and no water to ice maker?
pull fridge out
unplug
turn off supply faucet to ice maker
check line and fridge connection for the leak usually at the frige.
repair as necessary
turn on water
check for leaks
Mike
May 11, 2016 | Refrigerators
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
Leak on the ice maker water supply
Good day,
The house water supply is connected to a dual water valve on the bottom rear of the machine. It splits there going to the ice maker and water in the door.
If the ice maker side is feeding water to the ice maker even though the ice maker is in the off position means the diaphragm in the valve is leaking and must be replaced. Very common problem.
Apr 11, 2010 | Refrigerators
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
Water line from house supply sprung a leak just before going into the ice maker control unit in the lower right cornor of the frig. After replacint the water line the water did not flow into the control...
What once was a leak is now no flow and no response when trying to turn on ice maker? Is the valve where the ice maker line taps into turned back on? If it's back on, first turn it off, take loose water line as close to ice maker as possible, then have someone else turn valve at tap slightly on while you watch for water flow. If no flow, start back-tracing your connections until you find the blockage. Most water connections of this type have a in-line filter. Is it clogged? If you have water pressure as close to the ice maker as you can test, next you may need to troubleshoot the ice maker it's self. Let me know?
Jan 02, 2010 | KitchenAid Superba Architect KSCS25INSS...
My superba is leaking water from the white block where the water feed line goes into the ice maker how can this be fixed ??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak
. Disconnect the ice maker line from the water inlet valve valve(on the back where the water supply connects). and watch to see if it has a slow drip.
Nov 19, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
Ice maker supply system leaking at back of freezer wall.
replace water valve and remove ice from tube leading to icemaker.
Jan 14, 2008 | Hotpoint HSS25GFP Side by Side...
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
133 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
