Question about Refrigerators
Stopped cooling/freezing still sounds like it is running
Yesterday morning I thought one of the kids had left the freezer door open since there was water all over the kitchen floor and the food in the freezer had started to thaw. This morning I discovered that everything in the refrigerator was luke warm. There is no cool air at all, however it sounds like the unit is working. It has not made any strange sounds. We purchased this at Lowe's in 2003 and have not had any problems up until now.
The condenser went out - had a repair man fix it,
Posted on Apr 24, 2009
Yesterday morning I noticed that the unit was buzzing. The refrigerator door had been left open and the temperature inside was 70 degrees. The freezer temperature was 20 degrees. This morning, 24 hours...
Hi
You have condesation built up in your freezer whereby the evaporator fan or the vents are most likely blocked off.
Turn fridge off. Empty freezer and either put a pot of boiling water inside freezer or with the aid of a hair dryer try to defrost the freezer. If you are able to remove the back panel on the freezer that would be ideal as you can directly target the frost.
Good luck
Ash
Sep 06, 2011 | Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Hi, My refrigerator has been working perfectly for ten years. A couple of nights ago I noticed that it had wasn't freezing the ice and water dripping down inside the freezer part at the internal of the...
peter if your unit doesent seem to be cooling and the commpressor sounds like its running sounds wierd but make sure the fan cooling the evaporator coils is running if there is a lot of dust also clean the coils just a thought
Apr 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
the fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
Mar 09, 2010 | Kenmore 73503 Stainless Steel Bottom...
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Freezer door left open
if the alarm is sounding its probably trelling you the freezer is at too high a temperature. plug it in and leave it plugged in, it can take several hours to re freeze
Sep 16, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
