Question about Refrigerators
Not cooling - sounds like something is trying to start then clicks off
Model #FRT21LR7AW6 purchased new 09-13-2002 thru Lowe's.....not cooling, hear a click - then a humming noise for about 5 to 10 seconds - then it stops, as if something (compressor) is trying to kick in but it can't/won't
  • 358 Answers
Try first replacing the relay(located on the side of the compresor)wich the part won't cost more than $20.If doesn't work the compresor is stuck or burned and you need to replace it.
Posted on Apr 19, 2009
Clicking noise as furnace tries to start
If you have a gas or fuel oil furnace, that is your igniter trying to light the fuel. If it does it for a few seconds and quits without lighting the furnace, there may be no fuel getting to the burner. Check for fuel supply - oil tank empty? gas line turned off? etc
Jan 16, 2017 | Cars & Trucks
Kenmore elite refrigerator, both are "luke warm"
Sounds like your start relay/capacitor is fubar. The clicking is caused by the Klixon shutting down power to the compressor when it does not start properly. When it cools it resupplies power only to overheat and click when it shuts down again.
Jun 12, 2017 | Refrigerators
..hi there!...My Whirpool fridge has stopped
yes if the clicking is coming from the compressor,change the start switch and the relay it comes in a kit,,,that should fix it....these parts are located on the left side of compressor,,please unplug unit before doing any repair..
Aug 29, 2011 | Whirlpool Refrigerators
My refrigerator & freezer has stopped cooling. The lights are working, the fan runs, the coils are clean as well as no build-up of dust, etc. however, the condenser is not coming on...all I hear is a...
You have a compressor that is trying to start but is not able and is going off on overload. A tech can try a "hard start kit" if the compressor is still unable to start then don't spend any more on it, get a new fridge
Jun 22, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My unit is 6 years old and just stop cooling, both sides. I can hear a fan but no cooling.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 21, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
ED5SHEXKQ01 is 7 years old. Stopped cooling. Fan is running.
It could be your compressor trying to kick in. Or it could be your defrost system trying to start or stop. The least expensive thing to start is to replace the start kit on the compressor. Call or email us and we'll be sure to get the right part to you asap. You need to turn it off NOW before you burn the other parts up and don't turn it back on until you install new parts.
Sep 09, 2009 | Refrigerators
Refrigerator not cooling
the most likely problem will be the start relay for the compressor. the clicking noise is the compressor trying to start and then the relay cycles back off. the part number is 8201786 and can be purchased from any loal appliance parts house thru sears.com or any othe online parts source. the kit comes with good instructions so you should be able to repair yourself.
it would be a good idea to unplug the refrig until you get it repaired to prevent possible compressor damage. thanks peyton..
Feb 22, 2009 | Kenmore 53532 / 53534 Side by Side...
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
Clicking noise from under the dishwasher & Its a new dishwasher
Maggie, what you are hearing is probably the drain pump solenoid. At start the drain pump will get in to get rid of any water and purge the system. It's hard to tell without being there. I would call for service, it won't cost anything. Have the tech check the wash and drain pump assy. Catriver..post back.
Oct 28, 2006 | GE 24 in. GSD4060JSS Built-in Dishwasher
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
