Question about Kenmore Elite 45986 Front Load Washer
Stops washing and is making a clicking noise like a cricket will not spin or do any thing at this point.
    President:
  • 1,489 Answers
It's the motor coupling -- a $15 part
Posted on Apr 19, 2009
My kenmore model #110.42722200 washes but won't drain or go into spin cycle,it just makes a clicking noise.
this is caused by a faulty drain pump or broken lid switch tap the pump if it goes then replace it
Dec 26, 2015 | Kenmore Washing Machines
Noise while spinning
My 90 series kenmore washer. At the start of spin,makes loud clicking noise while it spins. Than it stops after a min. I changed the coupler. Still makes noise.
Jan 05, 2014 | Washing Machines
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Machine wont spin or drain.makes ticking noise when in spin or wash cycle then stops can you help?
if the timer is still running (ie the ticking noise) and it isnt doing any thing you may have a broken coupling - belt or the motor is shot
Aug 23, 2009 | Washing Machines
My washer makes a loud clicking noise when stopping the spin cycl
two things to check 1st check the pump for an object in it or the next thing to look at is the motor drive coupler do you see alot of black rubber and whiteish looking pegs if so rep the motor drive coupler you'll need 285753 or 285753a
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
Roper RAX4232KQ0 maker loud noise at spin cycle and then stops
There are a few things that can go wrong, If the washer doesn't adgitate or spin then probably the coupler is broken, lean the washer back and look under the machine between the motor and transmission you will find the coupler. (very common)
Coupler Part# 285753A $22.95
If its agitating but not spinning, check the lid switch, (easy check just listen for the click when you shut the lid, Or you can bypass it with a jumper wire under the console there are only 2 screw that hold the console down they are philips and either located in the front lower corners or the back lower corners)
Lid switch Part# 3949247 $42.95
If lid switch is good and the motor still doesnt run you might have a bad timer (RARE)
Timer Part# 3954563 $95.95
If you can hear the motor running but its not spinning and you have rulled out the coupler then your probably looking at a clutch (common problem) either the clutch isnt grabbing or the brake isnt releasing both problems solved with the clutch kit
Clutch kit Part# 285785 $44.95
Worst case your looking at a transmission, (uncommon) to rule out, make sure its agitating, then put washer in spin cycle. look under the washer to see if the clutch bell is spinning. if its not then you will need a transmission.
Trans Part# 3360629 $172.95
if its making loud noises when it stops spinnig then the block is bad.
Block Part# 389140 $14.95
Feb 07, 2009 | Roper RAX4232KQ Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
169 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
