Question about Amana SXD524VW Side by Side Refrigerator
Compressor not kicking in. sounds like it is trying to. everything else is working fine. not getting cold.
  • 358 Answers
Its sound like the compresor is off on overload ,eithe you have a bad relay(located on the side of the compresor under a black plastic cover ,cost about $20 or is a bad compresor wich cost alot more.I will try the relay first.
Posted on Apr 19, 2009
Amana srd23v fridge not getting cold, fan in back will not come on
Check power to the compressor start relay. If power there suspect compressor fault if compressor hot. If compressor cold, suspect start relay. If no power to relay, suspect control thermostat
May 17, 2012 | Amana Refrigerators
Moved my mds2434ge maytag side by side from one house to another. it was unplugged for maybe a day and half. plugged it back in everything worked fine for about 30 minutes then the compressor stopped and...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 17, 2011 | Maytag MSD2434GE Side by Side Refrigerator
A/C blows good cold air and everything works as it should, however when I turn the A/C on (doesn't matter what fan speed) I hear a constant clicking/ticking noise coming from what sounds like a fan
What you are most likely hearing is the compressor kicking on/off. The constant kicking could be a sign that there's insufficient refrigerant to keep the compressor running continuously without shutting on/off. Eventually, the compressor won't kick on at all, a safety feature designed to prevent doing damage to a compressor that's undercharged. Have the AC system checked.
Mar 29, 2011 | Kia Sorento Cars & Trucks
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
KitchenAid Side by Side
if you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Mar 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
My Whirlpool Fridg. Model ED22RF has a problem. The freezer is defrosting and neither side is cold. Sounds like the compressor switch is kicking on for a second and then off but the compressor never really...
yea that sounds like a compressor issue( under 5 year manufactrue warr.) you can try replacing te overload/relay assy mounted to the side of thecompressor , sometimes you get lucky and it works part number 4387767
Mar 26, 2008 | Refrigerators
Kenmore side by side not cold
the relay overload on the compressor is bad. very common problem. replace relay overload and it will work again. unplug from wall until you replace it.
Nov 26, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Amana SXD524VW Side by Side Refrigerator Logo
184 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
