Question about Jandy Ray Vac Pool Cleaner for Inground Concrete
Jandy pool cleaner will not move around pool - Jandy Ray Vac Pool Cleaner for Inground Concrete
  • 640 Answers
First, check your finger screen and energy filter. If they are dirty on these automatic pool cleaners, this can cause the unit to not move. Clean them if necessary. Next, check to make sure that the backup hydro-timer is not releasing most of the water out of the discharge hole. If it is, the unit will not move properly and you will need to replace the defective jet gear assembly. Finally, check to make sure that the transporter jet is not plugged up and that the debris chambe is not full.
Posted on Jul 20, 2010
Our dirt devil pool cleaner keeps sticking to the pool floor and will not move around, what do we need to do?
Make sure that your unifram is installed with the opening in a vertical position. If it is horizontal, you pool cleaners line will not have proper suction. You will also want to check for obstructions in the flapper that would cause the cleaner to not move properly. Finally, make sure that this is the proper cleaner for your pool size. If you have an in ground or very large above ground pool, it is possible that the pump you are operating with is too strong for the cleaner to move properly.
Apr 09, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
How do I stop the pool cleaner from stopping at the stairs and not moving around the pool?
These pool cleaners should not be having problems moving around the pool. I am going to give you several things to try. Check the return line water flow and redirect it if necessary. Make sure that your hose is long enough to reach all ends of the pool. Make sure that your hose has proper balance. Check that your main drain and all suction lines are completely closed except the one you are using. Check for debris in the filter, pump basket, and the cleaner's flapper.
Oct 10, 2010 | Zodiac Pacer Pool Cleaner
Is there an instruction manual for these cleaners out there?
Here is a copy of the users manual for these pool cleaners:
http://www.zodiacpoolsystems.com/Product-Archive/Cleaners/~/media/Zodiac/Global/Downloads/H05551.ashx
Sep 12, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Cleaner floats at the bottom of the pool and does not sit on the bottom or go forward
On these automatic pool cleaners, the finger screen or energy filter being blocked/clogged is often to blame for the cleaner not moving properly. Check them and clean if they look blocked. You will also want to check for a hole in hose that would cause it to lose pressure. Also, check to make sure that the transporter jet is not plugged.
Jun 19, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Goes in circles
you have a clogged line. disassemble and clean it very good
it should work fine after cleaning all ports out
May 24, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
May 26, 2009 | Pentair Jet - Vac Pressure Side Inground...
Jandy Ray Vac Pool Cleaner for Inground Concrete Logo
524 people viewed this question
Top Jandy Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jandy Garden Expert? Answer questions, earn points and help others
