Question about Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 will not stay turned on. i charge it at usb, but as soon as i unplug it, it cuts off.
Have the same problem on a 3 yr old unit cant wait to see the responses. will not take a charge anothersite said replace battery from mds batteries but I can not find a listing
Posted on Apr 19, 2009
    Problem Solver:
  • 9 Answers
You need to change the battery inside the unit. it's very easy to do. Just under the Garmin Logo at the top, you can feel a place to pull the face off.
Here I've turned the unit over and put a screw driver where the pull is. Just pull the face right off.
Once off, garmin streetpilot c330 will not stay turned on. - 2dc7397.jpg screws in each corner.
When pulling apart, keep note of the top of the Garmin unit. The antenna is right on top and drops easily. If you don't take note of the orientation, you may not be ablegarmin streetpilot c330 will not stay turned on. - c062787.jpgback. I've highlighted some points to keep in mind when taking this apart.
I can't stress enough how to be careful at this point. You need to remogarmin streetpilot c330 will not stay turned on. - f41f7e0.jpgy so that you can put it back. It's not hard but can be confusing.
Once apagarmin streetpilot c330 will not stay turned on. - cbbbdee.jpgre two screws holding the battery.
Behind this metal plate is the battery.
Unfortunately, the battery leads (black, red, green) also share the same plug as the speakers (brown, white). So you can guess that some soldering or taping of wires is garmin streetpilot c330 will not stay turned on. - c775f6f.jpghe battery can be purchased on Ebay.
Should you need a new USB plug, your better off purchasing a new unit. The USB port is soldered to the board and is not serviceable. Unless your really good with a soldering iron.
Posted on Apr 20, 2009
  • kathyhenders Jan 08, 2011
    Thank you for your post. I will try to find a battery at a local battery store, if not I'll go on ebay.
Brand new unit.Garmin c330, Will not stay on.
Since I didn't hear from anyone, I contacted the co. I purchased from. I was advised to send it back.
May 12, 2009 | Garmin StreetPilot C330 GPS Receiver
How to update my steetpilot c330 and my screen look funny
I would like to know if Nextar updates are avaikable to download.
Dec 13, 2008 | Garmin StreetPilot C330 GPS Receiver
I turned it on and it lit up and then completely died
Question: Why won't my StreetPilot c3xx power on?
Found on the Garmin web site --> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 03/10/2008
Oct 05, 2008 | Garmin StreetPilot C330 GPS Receiver
C330 Reboots when GPS signal obtained
My instructions for the C330 suggest resetting.
Unplug power and USB cables
Place thumbnail in groove located under Garmin logo on faceplate and gently pry off
Press RESET button for about 3 seconds
Connect to power source and turn back on
Hope this helps
Dec 17, 2017 | Garmin StreetPilot C330 GPS Receiver
No power to garmin c330
Does the unit turns on while pluged into the computer? If the answer is yes, then you will need to replace the battery. The battery is not taking a charge.
Jun 03, 2008 | Garmin StreetPilot C330 GPS Receiver
How to charge garmin c330 gps from computer
The unit came with a USB cable. Plug this into the GPS (when it is turned off) and it will come on and the unit will charge while showing an image of the GPS connected to a computer tower.
Mar 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Will not stay on
Connect the Garmin using the USB cable to your computer. Turn on your computer and let it boot up. Now turn on the Garmin. Does it stay on? If the answer is yes then the battery is dead. If the answer is no then you have something internally wrong with the Garmin. If the unit is still under warranty then get a RMA and send it back to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
353 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
