Question about Maytag Dependable Care LAW9406
Cold water just drips, hot is fine, good pressure.
The cold water just drips into the machine. the hot works fine. is there a way to clean the filter/screen where the hose attaches to the machine? do i have to replace the whole thing? Maytag Dependable Care
  • sandymrtn Apr 19, 2009
    Is there a trick to getting the little filter out of the little hole?
  • 10,865 Answers
Turn off water then remove hose. filter is in the fitting on the machine where the hose connects. pull out filter and clean or replace it
Posted on Apr 19, 2009
Cold water will barely flow into machine....already cleaned out strainer on incoming cold hose, water flows fine...however, once it hits the machine, it barely drips to fill up the washer. Hot water is...
bad water valve,the stuff you cleaned out of the screen most likely got inside the valve,another thing that can happen if you don't change the valve is that the valve can get stuck in an open position and it won't shut off and flood out your house.call the parts store give them the model number and they will sell you the right valve.next time send the model number and brand name,good luck.
Apr 30, 2011 | Washing Machines
My hot water works fine. The cold water only drips in. I took off my cold water line and cleaned the filter. Still only drips. Any advice would be helpful. Thank you.
You will need to replace the water inlet valve. If you could post your model number I will be able to direct you to the part you need.
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
Will not fill with hot or cold water and is connected
You need good water pressure on hot for these machines to work, gravity fed systems may not be enough. I had to attach a pump to mine to improve the hot water pressure (UK)
Switch over the inlet pipes ie hot to cold and cold to hot and try filling the machine when switched to fill with hot water, (machine will fill will cold). proving the valve is opening and it is a pressure issue on you hot water.
Nov 29, 2010 | Admiral AW22 Top Load Washer
Cold water filter is clogged - how to clean?
the water solenoid valve is cheap enough you could just buy new and put in. wouldnt waste my time trying to clean it just replace it.
Aug 01, 2010 | Estate TAWX700JQ Top Load Washer
Cold water drips in instead of fills. Hot water
Inlet screen in the hot water hose is clogged (check at both ends) or the solenoid valve has failed.
Oct 30, 2009 | Kenmore 22422 Top Load Washer
Cold water flows just fine, within 2 minutes the flow is down to
Make sure you clean both screens at each end of hose. If they are clean,you got dirt caught in valve. Good luck.
Jul 17, 2009 | GE Washing Machines
There is little to no water pressure in the cold
hi,
look into the inlet valves of the washing machine(where the hose connects to) and see if you can see inlet screens in the inlets, they are removable and you can can clean them but be very careful popping them out as they can get bent easily, hopefully that does it
J
Jun 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer works wonderful buy cold water settings do not work even rinse doesn't work hot water works fine
Would say that the cold fill valve is shot
The machine cannot fill with cold water which it uses for setting the temperature on the 60 degree wash.
The cold valve is also used for rinses
Hot water only will give you a wash which is too hot and will cause the colours to run
Can take the pipe off the back of the machine to see if the cold water inlet filter is blocked
Make sure that you turn the fawcet off and also that you have a cloth handy in case there is still some pressure on the hose.
If the filter is blocked take it out and clean it , it just pulls out but be gentle with it it is only plastic.
If the filter is clean you need a new valve
Jun 05, 2009 | Roper RAS8244KQ Top Load Washer
Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Mar 01, 2008 | Washing Machines
Washing Machines Logo
112 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
