Picture's gone--sounds fine!
I have an older 27 " Toshiba T.V....it has given us no problems, but just yesterday, all of a sudden the picture was gone...the sound was still there, but there was just one horizontal line going through the middle of the screen. I'd like to repair it myself if at all possible. I'm thinking it might be the picture tube??? If so, where do I get the instructions to fix it?
  • Tracy Bedard
    Tracy Bedard Apr 19, 2009
    Thank you VERY much for taking the time to answer my question! Appreciate it very much....I'll check into the solutions you gave!
  • 56 Answers
This is very likely not the picture tube. I suspect that something in the vertical oscillator section has gone bad. You will need to get the schematics for this set. Locate the vertical section and look at the transistors and IC's to see if they are still good. Also check for bad solder joints and open resistors. You can do all the checking with a simple Digital Volt Meter. You can get all the info you need online for how to test transistors, diodes, electrolytic capacitors and resistors. Most of my TV fixes have involved bad solder joints that have gone bad after years of hot/cold cycles , usually under a component that gets hot (heat sync) , resistor, or heavy item such as a transformer. The other issues are usually with transistors or IC's that have gone bad due to power surges or age degradation. Sometimes fuseable resistors open open. Sorry I can't be more specific. There are too many things to check. Could also be a power supply issue. but highly unlikely if you still have a center line. TV tubes hardly ever go bad unless the set is very old.
Posted on Apr 19, 2009
My mirai DTL-832E600 t.v. now has a white screen, and picture has gone negative (I think) or at least looks overexposed. It changed to this state suddenly yesterday when viewing.
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2014 | Televison & Video
We have a scenium rca ,suddenly the picture looks like a paint by number....any ideas?
One of the integrated circuit chips has given out. The TV digitizes incoming signals, then processes the picture in layers. One part of the process is adding the colour. This is done by the Painter Chip. It sounds like your painter chip, or some part of the circuit around it, has given up.
Diagnosing exactly why the chip has gone faulty and then repairing the defective part is going to cost a chunk of cash. So weigh up the whether it's worth investing in an older TV versus replacing the set for new.
Sep 09, 2014 | Televison & Video
My TV's video is out. A straight line goes horizontally along the screen. The sound is fine. It use to come and go, now it is gone for good. Does a tube need to be replace?
Hello.Theres a loose connection in your CRT board of your television.The problem is in vertical section maybe the vertical output IC is cold solder.Thats why harizontal lines appear in the screen of your TV.Your picture is good the problem is in the CRT board at the vertical section.
Jul 03, 2011 | Toshiba 27A45 27" TV
My sound as gone on my toshiba regza tv
Does the sound icon move up like it should on the screen when you increase the volume?
Dec 09, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My 27 inch Toshiba lost its picture. Sound is OK
If you can solder, YES, just replace the Vertical IC and check for any cold solder joints and open supply resistor. If not, it's not a major repair for a pro.
Aug 14, 2009 | Televison & Video
I have a Toshiba 42WLT66 LCD TV approx 18mths old that has suddenly started to lose its picture. Sometimes the screen will switch to coloured lines then fade to a blank sreen, other times it switches...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 01, 2017 | Toshiba Televison & Video
No Picture just sound from Toshiba 37hl17
IT is the Y Sustainer board blowing fuses. IT has 2 fuses. I have worked on severl of this model and the Y Sustainer board goes bad and blows the fuses.
Feb 22, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
No picture but i do have sound
Maybe your tube has given in, if the tv is old this more likely to be the problem...
swampy
Feb 04, 2008 | Toshiba 27D46 27" TV
No picture and no sound,
Something shorted and shut your set down. Most likely the high voltage transformer shorted which also shorted the horizontal output transistor. Stargazer
Aug 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
