Question about Akai LCT2721AD 27 in. LCD Television
Very low sound when using the internal dvd player
The TV has great sound but when I play a dvd on the internal dvd player I can hardly hear the sound-even when turning it up all the way.
  • 1 more comment
  • Marcine Dec 14, 2007
    I have same problem, great sound but when I play a dvd on the internal dvd player I can barely hear the sound-even when turning it up all the way so we have to use English Subtitles to get the dialog.
  • kuatojosue May 11, 2010
    the tv works perfectly, but the internal dvd player has no much sound and can not play -stop it with the remote control.
  • Anonymous Mar 18, 2014
    I play it through pvr and it is very soft even if it is turned to 100
  • 62 Answers
This is a known problem - there is no fix - if the dvd mech is replaced, the volume will still be the same. Sorry - - inside info
Posted on Mar 29, 2008
SOURCE:
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
Jan 23, 2016 | Sansui 19 in. LCD TV
Very low audio sound from recorded dvd
Could be the way it's connected, scart leads are good at causing problems! Does the box have a volume control? If so turn it up and leave it alone then. If you need to adjust the sound when watching use only the TV volume control.
Apr 05, 2010 | Televison & Video
TV after removal of picturetube for playing music from DVDplayer
Why use the TV in hearing the sound from DVD
player. You can use some small speaker and connect it at the back of the DVD player.
Jan 07, 2010 | Televison & Video
Using DVD+R i can burn an audio/video which plays
Tha's because not all dvd players can read DVD R+. Get a DVD R- and you will see how nice you can watch the videos in your DVD Player.
Aug 15, 2009 | Lite On SOHW - 1633S (show1633sbk)...
Have to turn the volume to 80-100 to hear the tv in my bedroom
If it's just playing DVD's that the volume is low some DVD players have their own volume control.
You could look at the back of your tv and see if the dvd or psp is hooked up to a "line in" or a 'variable' input. The Line in is a constant audio source. The variable will be also affected by the volume on the TV.
May 31, 2009 | Televison & Video
I can't get any sound from it.. just great visual...what can I do?
Yellow plugs and jacks are the Video and that works. Red and White are the RCA sound wires from the DVD to TV.
OR
Your sound goes from the DVD to TV via a Fiber Optic or Fire Wire.
OR
You use Ch 3 on the TV and watch the DVD through a TV Tuner and use the TV Antenna Cable between the DVD and TV.
If that didn't help, let me know for more things to check like Audio settings on the TV.
AL
Apr 26, 2009 | Televison & Video
DVD sound a problem but is playing ok.
try changing your dvd audio settings to stereo
Nov 12, 2008 | Toshiba SD-2800 DVD Player
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
Feb 05, 2008 | Sony HT-DDW790 System
Sound
Sounds like a cable problem. I get this a lot with my coaxial cable, it takes a little turning or playing with to start working. Use an optical cable if you have the option, they are more secure, or if you don't mind going analog use the red white rca cable. Either that or replace the coaxial, if you're using one. If your amp/TV, whatever you're connected to, has a vacant audio input jack to switch to, try that as well. Good luck
Jun 06, 2006 | Cyberhome CH-DVD 300 DVD Player
Akai LCT2721AD 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
