Question about HP DeskJet 5150 InkJet Printer
Printing differently than what is on screen
This is a random thing. But, sometimes when i print a document all the text is Times New Roman on the screen, but comes out a mix of mostly arial style font and a mix of Times New Roman. Any way to fix this is? thanks
  • 24 Answers
TRY PRINTING THROUGH MS WORD. OPEN MS WORD - CLICK ON FORMAT - FONTS - IN FONTS PAGE : SELECT TIMES NEW ROMAN UNDER FONT , REGULAR UNDER FONT STYLE , FONT SIZE AS DESIRED. UNCHECK EVERY OPTION OK CHECK WITH A PRINTOUT OR ELSE CLICK ON TIMES NEW ROMAN UNDER FONT AND CLICK ON DEFAULT, THE SYSTEM WOULD ASK YOU IF IT HAS TO BE SET AS DEFULT-SAY YES.
Posted on Sep 24, 2007
Font size change
If you are printing from word open up word select view from the drop down list select toolbars select standard formatting
Open up word across to the left you will see arial times new roman arial black next will be more to name a few of the different languages from the drop down list your documents will be read in next to that will be a drop down list with all sizes you can change the sizes of text
Open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
If its a web page
Right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the VIEW tab from the drop down list will be a Zoom with percentages %
Sep 13, 2013 | Posiflex PP7000 Printer
Tip
How to Remove Scratches in Stainless Steel
Whether you can remove a scratch has much to do with how deep the scratch goes. Here are several ways to deal with this problem and restore your cookware, stainless steel appliances, countertops or sinks to their former glory.
Consider using a product made for stainless steel such as Scratch-B-Gone or Bar Keepers Friend.
Or, try spraying an all-purpose cleaner (such as Formula 409) on the scratches.
Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
Rinse the surface and wipe dry.
You may also use a solution such as WD-40 to help fill in the sctraches and coat the stainless steel on the unit(s).
on Oct 19, 2011 | Frigidaire Refrigerators
When I cut and paste in microsoft word, the copy has a variety of differences from original, why?
Does this help
The text that you move or copy can have a font or other kind of formatting applied to it, such as bold or italic, that differs from the document where you are pasting the text. For example, you can move or copy text that is bold, 10-point Times New Roman, and paste it next to text that is regular, 11-point Calibri. If you want the pasted text to be in Times New Roman instead of Calibri, you can preserve its look.
  1. Select the text that you want to move or copy, and then press CTRL+X to move the text, or press CTRL+C to copy the text.
  2. Click where you want to paste the text, and then press CTRL+V.
  3. Click Paste Options za010181056.gif, which appears after you paste the text.
Mar 26, 2013 | Microsoft Office Home and Business 2010
The page i insert for scanning is small but the print of the scanned document is large. how?
if you are using word open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial times new roman arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
hope it helps
Jun 06, 2012 | Epson T073n Ink Tx110 Tx210 Tx410 Tx550w...
Acer aspire one zg5 no erecovery Pls Help.... Running on Win XP
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 27, 2011 | Acer Aspire One PC Notebook
I have an asus eee pc 4g (linux) and i want to change finnish languge to english. please help....
Changing Languages:
  1. Click on start
  2. Control panel
  3. Regional and language options, there you have the option to change the language to pretty much any language that you want
Sep 26, 2011 | ASUS Eee 4G Notebook
I want to change my font and the size of print -Desire ARIEL and print size 12
also open up word across to the left you will see arial,times new roman,arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
if you scroll to the top toolbar (top of screen) you will see the view tab select that then from the drop down list you should see a zoom with % and a text size with largest to smallest
if you dont have these in the toolbar you will need to add them
right click in the toolbar select menu
when you want to print opoen the document select file then from the drop down list select print preview you could select edit then click select all and change the size of your print
hope this will help you
Aug 24, 2011 | Computers & Internet
How do increas the print size in my computer?
open a document you want to print select file in the top left hand corner then select print preview from the drop down list ther should be another drop down list with percentages
30%
40%
50%
etc....... this is on a web page
the same should be on the page if you have made a word document
sizes of text
hope this help you
Aug 19, 2011 | Computers & Internet
When printing, sentences over lap so the document is unreadable. Also it may only print the first line of a document.
I've seen word documents do this sometimes and fixing it has worked differently each time.
1) Open the document and press CTRL + A (select all) on the keyboard and then CTRL + C (copy), then start a new document and press CTRL + V (paste). Save the new document as something different and try printing again.
2) Open the document again and select all and copy again,but this time open wordpad (a different program to Microsoft Word) by going to Start > Programs > Accessories > Wordpad, and paste the text into wordpad. This may change some of the formatting. Now, select all again, and copy, and start a new word document and paste.
Copying the text out of word and back in seems to work more often. Sometimes the best program to copy out to is notepad, but you lose pretty much all of the formatting when you copy back into word.
3) If this doesn't work, you could try to update your printer drivers, and if that doesn't work, as a last resort, you can delete the printer and create it again via the Control Panel > Printers.
May 04, 2011 | Office Equipment & Supplies
Epson fx-2175 not supporting Times New Roman font in PDF document
i suggest to update your acrobat reader to a better version (e.g. 8)
As i know acrobat 7 has some font issues which you described
Jul 27, 2009 | Epson FX 2170 Matrix Printer
HP DeskJet 5150 InkJet Printer Logo
143 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
