Question about Mitsubishi WS-65513 65" Rear Projection HDTV
1080 mitwubishi tv,cannot get to come on green light just blinks
We had a series of power failures and now the tv just sets there and blinks that green light nest to the reset hole. I have tried everuthing I can think of as well as the solutions on the net but nothing helps
    President:
  • Mitsubishi Master
  • 1,779 Answers
I would say without taking voltage readings, your Regulator IC in the power supply has had it. It's still worth repairing if that's the only problem. Contact your local Service co. for an evaluation and an estimate first.
Posted on Apr 19, 2009
Mitsubishi hdtv 1080 what are the blinking green light codes
ost models have a self-diagnosis feature to help determine shutdown problems.
To enable this feature do the following....
1) Turn the tv on and then let it shutdown
2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
This will commonly be one set of blinks followed by a short pause then another set of blinks.
This will repeat around five times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
2 - 3 = Deflection protect
2 - 4 = Vertical protect
Note: A constant blink on certain models will typically be caused by a fault in the DM model. To repair this check out site a "blinking green light kit"
Aug 05, 2014 | Mitsubishi WS-55513 55" Rear Projection...
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
"i have a mitsubishi HDTV
The green blinking light is telling you the error code. count the number of blinks and make note of any sequence. Then google your make and model with blink codes added to the end. This will lead you to sights that will tell you what the error or blink code means.
Aug 20, 2011 | Mitsubishi Televison & Video
Older medallion 55" 1080...switched itself
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
I have a mitsubishi 1080 series tv. I turned the tv off and then I went to go turn it on, now the little green light on the tv stays on for 2 sec. and then goes away without the piture ever coming on.
A hint--if the green power light comes on for a few moments and goes off do the self check this set has.
On the front of the set press and hold BOTH THE MENU AND INPUT (OR DEVICE) BUTTONS BOTH FOR AT LEAST 5 SECONDS. Release both buttons and look at the power button.
If this is the case the power light will blink a two digit error code--most common in this case is 2 blinks, a pause and 2 blinks--it will repeat the code up to ten times.
Let me know if you find an error code or the power light just blinks and never stops.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
I have a problem with a proj. TV mitsubishi model WS55809 1080 series. When I push the power bottom the click relay sound but doesn't work (rapidly
try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
SD TECH
Dec 11, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
TV won't turn on
There is a failure in the scan amplifiers, and or the power supply. This will require trouble shooting by an experienced TV tech who has access to the service manuals and know the set.
There are many components in the set that can cause this type of failure.
Did you not take an extended warranty???
This type of repair is not low in cost to have done.
Jerry G.
Jun 05, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
