Question about InFocus ScreenPlay 7205 Multimedia Projector
Need instructions on how to reassemble lamp and housing
  • 19,396 Answers
For all Owners of Screenplay 7205.
The procedure to replace the lamp is illustrated on manual. Check at page 32 .
Manual available here: ScreenPlay 7205.
Posted on Oct 31, 2009
BULB IS BLOWN ON THE MITSUBISHI WD65733
your model uses the Mitsubishi 915061010 Lamp assembly with housing which is available from www.tvrepairworld.com under the Mitsubishi DLP Lamp category. The lamp comes with installation instructions and is a simple plug in , It includes the housing so you dont need to remove the old bulb from your housing to reuse since the new lamp already has the housing with it.
Aug 22, 2011 | Mitsubishi WD-65733 65" HDTV
Price for XL-2400 sony replacement lamp with housing for KDF-E50A10 Grand Wega
You can get them from many places but you want to get the lamp with housing most places only sell the bare lamp annd then you have to install the new lamp into your housing being careful not to touch the lamp . You can get the Sony XL2400 lamp with housing from www.tvrepairworld.com which is 159.00 and includes installation instructions which takes about 2 minutes and no special tools required when you get the lamp with housing as an assembly.
Aug 13, 2011 | Sony Televison & Video
Projection lamp expired. how much is it to replace it?
you need the projector model number to find the proper projector lamp as not all projector lamps are made equal.
here are some sites you can find more information. just search based on your projector model.
http://www.projectorcentral.com/Sony-lamp-suppliers.htm
http://www.myprojectorlamps.com/
Projector lamps range from price. Low $100s to $300s based on the projector brand and model you have.
Mar 06, 2011 | Sony Televison & Video
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    How do I change the lamp in this tv? Do I need to buy just the lamp or lamp with housing?
    If you have not changed a lamp before at all, I would suggest that you purchase the lamp plus housing. This will contain complete instructions on how to change the lamp and reset the counter. Keep the instruction sheet and the old housing and you should be able to replace just the lamp the next time.
    Dan
    Apr 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
    Chage lamp on Pt-43lc14-K
    On the front, under the screen there is a large plastic cover. The far right side of the cover has the black decals "HDTV 1080i" and "VIVA bb3 sound" on it. There aren't any screws holding it on, just pressure snaps. Pull the sides of it off gently and the three or so foot long panel will come loose. You'll see a black plastic panel now with two doors, one in the middle and one on the left of the middle door. The one on the left has a white lamp warning label decal and a black screw holding it in place. Remove the screw and take off the door. Inside is the lamp housing. Some models have a a screw on the right side of the black plastic housing, holding it in place. Take out that screw and pull the housing directly out toward you. You now have the lamp housing. If you are replacing it with a new lamp and housing just push the new on into place and reassemble, you're all done. If you are replacing just the lamp, you have a little more disasembling to do. But its not hard. If you need further help, post a comment and I'll send pictures. Good Luck.
    Jan 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
    Instructions on replacing the bulb not the housing
    It's not too bad to replace just the bulb but rather more difficult to find just the bulb on it's own. The guys at lumenarc.co.uk should be able to give you just the bulb. As a start, you might want to have a look at this video:
    http://www.youtube.com/watch?v=Xsr3mmLwfNk
    Jan 16, 2009 | Sony (XL-2400) Projector Lamp for...
    Where is the lamp housing unit & how do I remove it?
    The lamp is in the front of the TV. Pop off the gray cover, about the width of the screen, located just left of the power button. You will then see a bunch of warning labels on the left. Unscrew the one screw that is there and take that piece off. There's your lamp. Unscrew the screw on the right of the lamp and the lamp will slide out.
    Nov 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
    Lamp out ...
    remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
    Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
    InFocus ScreenPlay 7205 Multimedia Projector Logo
    119 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
