I can't use the Winamp with the shoutcast server because i'm not able to forward the requested ports. I have the same Problem with the RadioDestiny Broadcaster in use with with my Zyxel Wireless Route
I can`t use shoutcast server because i am not able to forward the requested ports
Hey... don't worry, now shoutcast have they own player now... justo allow the pop ups on they website and that's it... good luck !!!
Posted on Apr 20, 2009
Port forwarding instructions
Port forwarding used to forward a port request from wan side to local systems on lan to use specific services provided by servers.
go to Setting, use Port forwarding option. Now click on Add. Enter the Local Ip address of system providing the specific service and then add the starting port number and ending port number, (it may be same). Now click on Save.
Aug 17, 2014 | NetComm Computers & Internet
IP Camera Port Forwarding
The best way to find out what is being forwarded is to look at the traffic with the Wireshark program. You can install this from the Internet.
Wireshark is perfect for this but you have to learn how to filter traffic or there will be too much information collected. It is also regarded as (a bit of) a burglar tool so don't use it at work without permission.
I would recommend that you connect a PC to a wired port on the inside LAN and configure the router to forward outside requests to the PC. When you run wireshark on the inside PC with a filter that selects for tcp port 80 (or tcp port == 80) you will see traffic forwarded from the router.
Use your outside machine to request a page from the router's outside address and the port you are forwarding. If you have forwarding set up correctly, you should see a TCP connection attempt. If you are not running a web server on the inside PC, there will be no connection so you will only see the SYN packet from.
outside. If you have a web server on port 80, you will see a fair number of packets in both directions. (SYN -- SYN-ACK -- SYN -- some HTTP Headers an HTTP GET / a response and FIN -- FIN-ACK).
Once you see successful port forwarding (your are forwarding TCP packets, right?) at the PC, change the destination of the forwarding to the camera.
This is really technical but Wireshark is so good that it is quite easy to use.
Sep 10, 2012 | Computers & Internet
I would like to know if there is a way, to broadcast from a web cam to another web site. I am a member of Utherverse, and I own a club. I want to do my own DJ, and video. Is there a way I can use a...
Install Winamp on your laptop you have you music that you going to stream.. install shoutcast DNAS server, configure it with a username and password.. when you fire up winamp, shoutcast DNAS should open together and you click connect on DNAS.. its going to broadcast your music.. you can also broadcast a picture of yours on the mix.. you can also configure it to sync with Virtual DJ..
May 13, 2011 | Computers & Internet
Am trying to set up a Windows 2003 server to serve web pages over the Internet. Have got a DSL line from Embarq. They installed a EQ-660R interface which is really build by Zyxel. I can reach the Internet...
In order to access your default web page remotely, port 80 "INBOUND" must be open to the internet.
To access your web server, two things need to happen.
The first is you or someone else must initiate a http request on port 80 using the public IP Address of your DSL connection.
Second, your router must forward that request to your servers internal ip address.
Ex. Lets say your public ip address is 24.39.45.10. In a browser window from a remote location, you enter the URL http ://24.39.45.10 The request will be sent to your router on port 80.
Your web server will not have the ip address 24.39.45.10 because it's on the private network side of your router. So, lets say the private ip address of you server is 192.168.1.100
You need to configure your router to take the http request coming from the internet on port 80 to ip address 24.39.45.10 and forward that request to 192.168.1.100. This is known as port forwarding.
You also need to configure the host header name of your "web page" so it knows it needs to display the web page.
Since we're just using ip addresses in this example and not an actual FQDN (fully qualified domain name), you would make a host header entry for the web page of 24.39.45.10.
To do this open IIS.
Navigate to the web site in question and right click on it then select properties.
On the website tab, ensure the port number is set to 80 and choose the appropriate internal ip address if you have more than one network adapter in the server.
Next click on the advanced tab and look for the heading Multiple identities for this site. This is where you enter the ip address 24.39.45.10.
If you have a fully qualified domain name, you would enter the domain name instead of the ip address as specified in this example.
Host header names are the key to running multiple websites from one physical server as long as it has the necessary horsepower to do so.
Hope this helps and isn't confising. If you're confused in any way, don't hesitate to ask for clarification.
Sep 13, 2009 | Zyxel P-660RU-T1 ADSL Ethernet/USB Router...
Having a problem getting DynDNS to pass through router and connect to my web server. Web Server can communicate with DynDNS, but an http or https request (ports 80 and 443) do not get to the server. I...
I did this with a cctv and another dns server and does not really work. So i just change my ip to static and open ports 80 and 443 and 8000 (server) and worked fine without using ddns or free dns. Oh and i use this to check my ports if they are working
http://canyouseeme.org/
Jun 13, 2017 | Encore ENHWI-N Router
How to Design a radio player in website by using javascript?
shafihot SERVER ERRROR Solution
How To Make Your Own Radio Station
Must HAVE Winamp (Any Version)
First, things First your speed has to be at least 256/64 kbps (which means Dial-up users, will have alot of latency, just dnt bother)
Second, your going to have to have a domain, an updated one with the current i.p active. (Could be anything e.g. My sig)
Now, Your gonna have to download the Shoutcast Files.
Go to www.shoutcast.com to get the files.
Ok After downloading these, installing Both of them in any order i dnt care. Go to START>PROGRAM FILES>SHOUTcast DNAS>EDIT SHOUTCAST DNS CONFIG.
Ok your gonna have to Configure it:
Go Down and where it says password: change (that means your gonna have to change it to whatever, make sure u remember)
The Portbase: change it to whatever port you want it
Maxusers: (lets be realistic here, dnt put in 10000, like NXS's radio station) your bandwidth has to be extremely good, if your cable, 50 user max is ok, ADSL should stay below 10 users, and T1 connections should do whatever tickles there fantasy.
Open winamp, RIGHT CLICK>OPTIONS>PREFRENCES>DSP EFFECT> and choose the NULLSOFT SHOUTCAST.
Go to OUTPUT, and then click on Connection, Through the ADDRESS, type your address which you have done through www.no-ip.com, PORT NUMBER, whatever u did in the EDIT.txt, and your password.
Then go to Encoder, and choose your quality of your music. Go back to OUTPU>OUTPUT CONFIG> YELLOW PAGES. this is your advertisemant information. dow hatever you like there.
Now Connect. to check that your Radio os on-line go to http://(your address that you added in the prefrence)
more detailes...
help
mail me shezrulezz@gmail.com
shezrulezz@yahoo.com
Jan 31, 2009 | Computers & Internet
I want to use my hp g2 server to set up an internet radio station
Ah , I have been down this road myself :-) ...... I can give you a few words of advice......
  • As far as the server itsef , it really doesn't need anything spectaculer in regards to hardware & specs.....a box running XP with 512mb of RAM would suffice...so your server should be fine
  • Bandwith - you are going to need ALOT of it if you are streaming more then 64kb's....typically if you are playing any sort of music you stream at 128kb....so make sure you have a hefty data plan!
  • For the server itself , use the "Shoutcast" software for hosting the station....it is easy to use , has plenty of support and documentation....you can literally have a station up in 5 mins!
  • For broadcasting you can use the Winamp program with the "Shoutcast DSP" plugin...but if you are playing alot of music , want advertisments and like to DJ I would recommend something like "SAM 4"
Just a quick overview to get you started , all you really have to do is download the shoutcast server software , edit the config file - which includes the admin password , the port to broadcast on , the max number of listners you want etc..........
You then need to do some port forwarding, opening up the port on your router and sending the connections to your server....actually doing it is easy, but it varies by router model, you can use this site for a step by step, just select your router , and then select "Shoutcast" http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
From there you launch the server program , and connect to the server with Winamp or SAM....and now your on the air!
SHoutcast documentation to setup DJ and server:
http://shoutcast.com/download
I have alot of exp. with this , you didnt really specify a specfic problem or question , so if you need anything else be sure to leave a comment here and I can help you even more!
Oct 02, 2008 | Computers & Internet
Port Forwarding on Bigpond 2071a
you need to go into the modem settings and open a port.You set a number 32599 and apply works perfect for me and then got into preferences at utorrent and set the 32599 number and apply now check to see if your port is open.
Aug 21, 2008 | Computers & Internet
Http access
Router cannot forward tcp requests to linux box if it has a http server already running on the same port. Make the router's web server listen on a different port.
May 22, 2008 | Siemens SpeedStream 2604 Router (obss2604...
Open Questions:
Need help! Backed up how do I restore and what restores 'Cloud Backup For Small Business Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jul 18, 2018 | VIA Computers & Internet
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
