Question about RCA F36650 36" TV
White washed image and horizontal lines.
Just recieved an older set from a friend of the family; moved the bulky unit less than gracefully to our home. Worked fine prior to move, now has what I believe are called "horizontal retrace," or white "flyback lines" running through the image on the still working set. Also, the image appears white washed, or faded.
Can't afford to have it service, and won't likely be replacing it, but would like to fix it myself.
Is there a brightness potentiometer on the flyback or anywhere else in the set that I can adjust to fix this? Or will it need some sort of replacement component?
Thank you for your assistance.
  • joseph_petti Apr 19, 2009
    I gave it a shot, but it didn't really do too much. The lines are still there, and it's still washed out. Thanks for the suggestion though.
  • joseph_petti Apr 20, 2009
    Unfortunately there doesn't appear to be any pots on the flyback. That was my first thought after moving the unit. I've basically given up on the unit, unless anybody else has any other ideas (short of replacing the flyback or tube itself) I think this tv is doomed to a slow death, agonizing death.
  • 700 Answers
Its retrace line is cause by overturn screen voltage. In can be adjust on the potentiometer of the flyback, slowly adjust it to a minimum level if this is a crt type. Just be cautious in dealing with this you are working on a live circuit.
Hope this additional input helps you.
Posted on Apr 20, 2009
    President:
  • 267 Answers
Sounds like you shorted an element in the CRT (picture tube) i have seen this same thing in a lot of portable tvs that have been banged around ,loss of contrast (washed out ) with retrace lines . i have fixed a few by LIGHTLY tapping on the neck of the tube with the handle of a rubber handled screwdriver at a few points around the neck , while it was on . if the picture goes clear you fixed it . but i must say you can easly break the tube tapping on the neck . so REAL EASY ON THE GLASS NECK !! .you should be checking the tube first for shorts with a tube tester .but i am sure you dont have one handy otherwise you would allready have your answer . good luck .........if this answer helped please rate 3 or 4 stars this high rateing will help keep me in the paid answer department , thank you
Posted on Apr 19, 2009
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | Toshiba Televison & Video
How to make my washer use more water
You cannot it is designed to be ECO friendly bulky setting will add a little more water but not much it will never fill to the level of the older washers
Aug 30, 2014 | Whirlpool WTW6400SW Cabrio Washer
My Canon Camera Powershot A470 has been registering the shot images, showing them with horizontal lines across the image. The lines look like the ones on the start-up "Canon" image when you open the...
there is a recall on the Powershot family lens.
check this Fixya's tip:
http://www.fixya.com/support/t114938-canon_digital_camera_recall_defective
Oct 18, 2010 | Canon Cameras
Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Machine moves two feet when washing bulky items
make sure the shipping bolts where removed from the washer and make sure the washer is completely level
Jul 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Image in LCD shows mulitple horizontal whie lines
This sure looks like a CCD image sensor failure. If so, you can't fix this yourself. If the camera is less than a year old, Canon will fix this for you under warranty. Call 1-800-OK-CANON.
Jul 08, 2008 | Canon PowerShot SX100 IS Digital Camera
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
White line across image
sounds like capacitor problems or a possible ccd problem or driver problem .Its time to send in the unit for an estiamate. Cont # is 1-800-NIKON-UX , 1-800-NIKON-US Good Luck
May 11, 2006 | Nikon Coolpix 5700 Digital Camera
RCA F36650 36" TV Logo
305 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
