Question about Acer Ferrari 1000-5123 Laptop
Usb port problems.. is it connected to motherboard problems??
Hello.. i have problem with my usb port.. it cannot recognised any devices that i plug in.. i have read many opinion and try it with my laptop but it's not working... even my internal digicamera cannot be recognised... the windows said that it is installed but it cannot recognised the driver... here i thought 2 main problems.. whether it is problem with motherboard or with OS... beside i have reformatted it once after the usb port not functioning... but nothing had been done... it still like that.. what is your recommendation?? and if i will change the motherboard.. how much it cost approximately?? mmm.. thanks for your kindness.....
  • 85 Answers
You do not need to replace the whole motherboard buy a pcmcia card with usb ports if your laptop supports pcmcia cards
Posted on Sep 19, 2007
USB port gives new message "unknown device"
hello allan213
my name is ausi.
is it on all usb ports only one of them if it is in only one of them then the message you getting generaly means one of thw follwng.
1- if it is in only one of the ports then try it with a different device as well to see if it is the actual port or not.
2- the device you have plugged in needs to have drivers installed. normally should have been supplied with it.
3- the device you plugging in is faulty and the system can not access it.
4- the system usb ports are overloaded. (too many usb devices connected simultaneously)
good luck
Jan 05, 2011 | Intel Motherboard
First disconnect PC from power cable for 10 minutes (unplug).Disconnect player from USB. reinstall player software. Then connect back player, it should work.
Apr 20, 2008 | Audio Players & Recorders
Usb ports not recognised
Right click on the yellow flag and uninstall the corrupt driver. Restart the computer, plug a USB device in and it should be resolved. If not post back.
Jun 29, 2010 | Gigabyte GA-G41M-ES2L Motherboard
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
LG GSA E 40 L External dvd writer not recognised
you may be having conflicts with usb devices. try temporarily removing all unnecessary devices from the usb ports. unplug and then plug the drive back in. you could try another port. if all ports are in use, then unplug another device, like the mouse and plug in to that port, then plug the mouse into the writers port. i had a similar problem with a wireless usb lan that stopped another device from being recognised. when i removed the lan and replugged the unrecognised device, windows recognised it. i obviously had to use the wireless lan, so i swapped that with the mouse and it worked.
Jul 19, 2009 | LG GSA-E40L Burner
Sony Vaio USB ports not recognised by XP
It is common problem on most of the PC USB ports does not recognise external hardware.It is mainly due to lack power supplied by the USB Ports..You can try with Old Pentium4 maschines.IT Reads well..
Another thing dont use extension ports to plug external HDD..always use backside on board ports.\
IF it helps rate me
Jun 25, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
USB device malfunction
i) try to connect pendrive to the usb ports present at backside of ur computer tower instead of usb ports present at the front panel of ur computer...............
ii) sometimes usb ports present at the front panel ofur computer might have loosen connections............
Thanking you
M. Sridhar
Jan 18, 2009 | Intel Motherboard
Usb port not recognising devices and mouse pad not responding
hello there. It sounds as if your motherboard (bios) is not configured correctly, or your windows drivers somehow got corrupted. check in your MoBo's manual to see how to access it's bios options. and make sure that your onboard usb options are enabled.
Nov 23, 2008 | Microsoft Computers & Internet
Usb port ceases to work when any device connected to second port
As you stated the device works in one slot but not the other , tells you there is problem with that usb port , don't use those ports , best thing to do is purchase a PCI USB card if you need more USB ports .
Jul 29, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
USB port does not recognize 1Mb flash drive
try connecting the card directly to your computer usb port. unplug other usb devices. if that fails, try the card in a different computer.
May 17, 2008 | ASUS P5P800-VM Motherboard
Acer Ferrari 1000-5123 Laptop Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
