Question about Singer 7462 Mechanical Sewing Machine
Foot pedal not working
Singer machine Merritt 4530, foot pedal number 979374-013: pedal was dropped, many small round circular metal pieces dropped out. Is this something I can fix or is it shop time? Thank you
  • Anonymous Mar 30, 2014
    Is there a compatible foot pedal for the 9900
  • 65 Answers
You can purchase that singer sewing machine foot control here:
http://www.sewingpartsdirect.com/foot-control-w-cord-singer-979314-031.aspx
Posted on Apr 21, 2009
I need a manuel for a Singer Merritt 4530 sewing machine
Most Singer sewing machine manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the Merritt 4530 is http://www.singerco.com/uploads/download/437_5_6_8_10_slide.pdf . Note: this manual applies to several machines with different available stitches.
I hope this helps.
Sep 01, 2017 | Singer Sewing Machines
Where would I oil a singer Merritt 4530 model machine
Singer has the manual for the Merritt 4530 on their manuals site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/437_5_6_8_10_slide.pdf . See page 44 for the picture of the points were you should apply sewing machine oil. You'll need to oil 8 points under the face plate on the left side of the machine. Most are places on the needle bar shaft. There are a few connected to the thread take up lever. If you move the hand wheel, you will see most of the points that need lubrication.
I hope this helps.
(In this case, the picture is much clearer than any verbal description I could give.)
Sep 21, 2016 | Singer Sewing Machines
Does the Singer Merritt 4530 uses the same footpedal as the 4530 c? My S Merritt 4530 c is 22 years old and I love it, but misplaced the footpedal after we moved.
Yes, the 4530C was only a variation to the 4530. It actually also fits a wide range of models, including some manufactured by Brother and J. C. Penney.
May 26, 2015 | Singer Sewing Machines
How to oil a Singer 2242 model ?
take the top off with a screwdriver. first, clean the moving parts with a q tip. you can use the foot pedal to let the machine move slowly while you place the qtip on the round areas. for the gears you will need to take time to clean without the machine running. after you do this take your oil and oil all metal against metal moving parts. replace the top. now, do the same on the bottom of the machine. replace the bottom cover. on the front of the machine you will notice places where the needle arm and pressure foot arm is going through holes that guide them. place a small amount of oil on the rods. the weight that is in back of the needle arm should be oiled in the back of it as much as you can. the bobbin carrier has an area that under it that rotates. it looks like a race track and is called race. put one drop on it. just remember all metal against metal is the key. clean!!!!
Sep 08, 2014 | Singer Sewing Machines
How fix singer foot control fuse broken lots little discs fell out of control
You didn't specify a model, but foot pedals are generally used by a wide variety of models of machines. Go to eBay and enter your machine's model number, and you'll probably see foot pedals for your model of machine for sale.
Aug 11, 2014 | Singer Sewing Machines
Is there free manual for singer merritt 2502C
There sure is! Just go to the Singer sewing machine site, and there's a page where you can type in your model and click the button, and your machine is right there for free download.
Jun 28, 2014 | Singer Sewing Machines
What is the secret to getting the bobbin holder back into the singer merritt 4530?
I have trouble with this every single time. What you need to do is remove the silver plate right under the needle. If you think of the case as the number 6, put the comma I just typed (a little piece of plastic sticking out from the rounded section at the bottom) under the metal at the bottom.
Then slide the metal plate at the top back on. You may need to turn the knob on the side of the machine (that makes the needle go up and down) to get it to go back on. At this point, as you're turning the knob, the bobbin case should fall back into place.
I just finished doing this myself. Now my issue is that the thread from the bobbin keeps knotting up.
Oct 24, 2010 | Singer 2932 Mechanical Sewing Machine
Singer 2010 doesn't want to stop
I have a Singer Merritt 4530.  I don't know if the foot pedal works the same way on your model, but on mine it is held together not by screws or latches, but simply by white plastic rods that serve as hinges.  These rods have a hole drilled in their center, presumably so some special tool can be used to pull them out.  Lacking a special tool, I glued a nail into the hole, and once the glue dries you can pull the nail and pull the rod out with it.  The rod is about an inch long and held in place merely by friction - no glue or screw threads.  Once one rod is removed, you should be able to slide the pedal off of the rod on the other side, though that might have only worked because some of the plastic housing was cracked on mine.  If you don't want to take the time to test that, just glue a nail into both rods and pull them both out.
Once you get the pedal open, mine had a giant white cylinder that looks kind of like a battery or a fuse.  This thing was getting very hot the longer the pedal was left plugged in.  I read on many web sites that this object can cause overheating or short circuit the pedal so it's always sewing.  It's called a suppressor and can be safely thrown away.  I haven't found an explanation for precisely what it does or why it can be safely thrown away, but I theorize it's a surge suppressor and that most modern wiring isn't going to surge too much.  I got rid of it and the pedal still works and doesn't overheat.  It may be safest to plug the machine into a surge-protected power strip once the suppressor is gone - just my theory.
Feb 02, 2009 | Singer 132QRFB Mechanical Sewing Machine
Adjust timing on Singer Merritt 4530
what size replacement needles for a singer merritt 4530
Oct 21, 2008 | Singer 7462 Mechanical Sewing Machine
How do you thread a singer merritt 4530 sewing machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Jul 14, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
1,109 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
