Question about GE Computers & Internet
Start Menu & Taskbar do not appear
WE have just installed a Gainward GeForce FX5200 128MB onto our Dell 3000 and the task bar and start menu does not appear. We cannot open these from the Control Panel but everything else in the Controll Panel opesn and is functional.
  • everyfamily Apr 19, 2009
    We have adjusted the screen resolution to the smallest & largest possible and still no sign of our errant start menu & task bar. We are accessing the control panel through My Computer.
    President:
  • 778 Answers
How are you accessing Control Panel without a Start Menu or Task Bar? You may want to check/adjust your screen resolution in Display Settings.
Posted on Apr 19, 2009
  • Frank  Fernandez
    Frank Fernandez Apr 19, 2009
    Find your Graphics Card in Device Manager and try to update the driver.
How to get taskbar back
Hi, if your on a Windows system press the Windows key to open the Start menu, in the Search option at the bottom type taskbar, this should show you Taskbar and Start Menu option.
Select the Taskbar and Start Menu option
Check the AutoHide option is not ticked, and check the taskbar location is set to Bottom, if you make any changes click the Apply then ok.
Aug 28, 2014 | Computers & Internet
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
THE TASK BAR APPEARS AT THE TOP OF THE WINDOW
First, make sure the taskbar is not locked. Right click the taskbar and make sure the is no check mark beside 'Lock the taskbar".
Now, point your cursor just beside the START button (outside the START orb and on the task bar), click and hold and now you can move it to the bottom of the window.
Jul 13, 2010 | Dell Computers & Internet
Missing task bar - running vista
Sounds like explorer.exe is not running:
1. Hit Ctrl + Shift + Esc at same time.
2. Windows Task Manager should open.
3. Hit File on top menu.
4. Select New Task.
5. Type explorer.exe and hit OK
That should bring your task bar back.
Jun 02, 2010 | Microsoft Windows Vista Home Premium...
Task bar is missing on bottom of screen after pc wakes up.
mine does this with windows 7, right click on desktop and open 'personalize' then open 'taskbar and start menu'
From here choose to move your taskbar location to the side of the screen and click apply. it should return, then just tell it to go back to the bottom.
Sep 18, 2009 | Dell Studio XPS 435 PC Desktop
How to apply color to start menu and taskbar in windows vista
These little things can drive you crazy...so let's go...Right click in an open area of your desktop-at the bottom of the box that opened- click on Properties then- Appearance tab- under Windows and Buttons- select -Windows Classic style. Now in the -Color scheme- select Rose or whatever color you like...then click on Apply and then OK.
I think you are missing the Apply and then OK.... this will do it for you, Enjoy your world of Roses..bye
Mar 21, 2009 | Dell Inspiron 1525 Laptop
My taskbar does not appear when I am viewing web pages
It sounds like you have your task bar set to auto hide. I'm not too familiar with this brand of laptop but if you are using windows you should be able to follow these instructions to fix this. If you know how to get to the control panel (start menu) and click on appearance and themes there should be a task bar and start menu icon there. Click on that icon and select how you want your task bar to be displayed.
Nov 10, 2008 | Acer Aspire 5100 Notebook
I cannot re install my start up bar the file display
In XP, go to Start > Control Panel > "Taskbar and Start Menu" and open it and you should be able to show and lock your Task bar aka "menu bar" from the Taskbar/Start menue options you'll see there.
Good luck.
Feb 24, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
78 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
