Question about Flotec 3.4 Hp Floodmate Submersible Sump Pump
My engine on my pump got wet is it ruined and how does the wiring go on it beacause ther is a green and two black wires
  • 35 Answers
Likely its not ruined Power to the 2 plack and Green is for Earth Ground
Posted on Apr 19, 2009
  • Noel Coward
    Noel Coward Apr 23, 2009
    Likely its not ruined AC Power to the 2 black and Green is for Earth Ground
MAF enhancer installed on wrong wire - engine codes
what does your MAF consist of ?
what did you get for instrusction?
is it just a resistor?
what are your troublecodes?
does the engine run fine without the enhancer installed?
Sep 20, 2008 | 2003 Volkswagen Jetta TDI
I disconnected the pump and need to know where the red black aND WHITE wires go
Hi, this is John the Hayward tech. You say the wire colors are Red, Black and White. Does not seem that the wires colors were correct from the start. Not knowing your voltage let me clarify some things. Normally if you have 115volts coming into the pump you wire colors should be Red or Black to L1 White to L2 and a green ground to the green ground screw. If you have 230volts coming into the pump the two hot leads are normally red and black with a green ground. The red and black wires go to L1 and L2 does not matter red or black. The green goes to the green ground screw.
Sep 03, 2014 | Pool & Spa
How to wire emerson pool pump to switch box
The green is ground. The other two wires connect to white and black. The motor should come on. IF you take the black wire from the power cord and disconnect it from the motor black wire and install a switch there. You can control it.
Jul 24, 2014 | Emerson Pool & Spa
I am replacing an older polaris pb4-60 with a new polaris pb4-60...when moving the power cord to the new pump i have 3 wires, a green, black and yellow...I know the green is the ground, but which poles do...
if across the black and yellow you have 220 volts ac then wiring from factory ok black to L1 yellow to L2 and green to ground or case if 120 volts see side of motor for wiring
Jun 09, 2012 | Polaris Pb4 - 60 Booster Pump
How do u wire this pump grn whi black wire
Green wire wile go to the green screw on the pump casing. The white and black will go to the line screws on the wire board.
Nov 27, 2010 | Aqua Flo 3 HP Aqua-Flo Pump: 2" in/out,...
Low voltage to fuel pump
there is a factory bulletin on this problem, it is the connector to the pump module, they get overheated, the pins loose good contact and u get low voltage, there is a repair connector availiable from GM and from a Company called Airtex
AIRTEX Part # WH3005 {Wiring Harness; 1x4 Spade Style Connector}
Wiring Harness replacement recommended. Price at rockauto.com $8.93
Jun 04, 2009 | 1999 Chevrolet Silverado 1500
Fuel light stays on 02 gsxr 1000
check for open wire on the harness going to
color/stripe
4 wires fuel pump & level wires
yellow/red,black/white are pump wires black/lightgreen,black/white
3 wires Fuel resistor module wire colors blue/Lightgreen,orange/green,red/black
o1 manual
Apr 06, 2009 | Suzuki GSX-R 1000 Motorcycles
My fuel pump dosen't work all the time and i just replace it.
There are 2 connectors on the alternater. The round one has 3 wires. If there is no voltage on the green wire when the engine is running the alternator is bad. I'm not sure what fails internally but the alternator can put out fine charging voltage on the main black lead and not have voltage on that green wire. That wire is a trigger for the fuel pump relay. Voltage goes to the main power relay then to idiot lights in the dash then back to trigger the fuel pump relay. Along the way it goes in and out of the oil pressure switch(sender at the back bottom of passenger side of block with 2 yellow wires). This switch cuts voltage to fuel pump if no oil pressure. The green wire from alt is a safety in case of collision ect. Engine not running> no alt voltage on that wire>no fuel pump pressure>no fire. If this wire is bad it will not show up on the standard auto store test. And is a common failure. I had an brand new Isuzu rebuilt OEM alternator that was bad like this.
Jan 27, 2009 | 1997 Isuzu Rodeo
Flotec 3.4 Hp Floodmate Submersible Sump Pump Logo
150 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
