Question about Sharp Aquos LC-20B2U 20 in. LCD Television
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
Sharp Aquos LC20B2UA set dead as a doornail. A blown fuse just inside the on-off is likely culprit, but I cannot find 2A-125v replacement anywhere. I could use a 2A-250v, but what if the real problem is elsewhere? Need fuse to troubleshoot further. Dave in CA at dbasshat@comcast.net
  • 41 Answers
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Posted on Apr 19, 2009
I have the same problem, my Aquos blows this fuse too and I install a 2A 250 v fuse and he just work for one day, the other day the fuse was gone.
Someone told me, the TV have to use the manufacture specifics
Posted on Jun 03, 2009
Is there a fuse inside the grinder to protect it from an electrical surge. I accidentally plugged it into a 220 volt outlet.
My MDF was built in September 1993. It has a fuse inside a black cylindrical fuse holder on the electronics board that sits aside the motor. If you have a right-angle flat blade screwdriver, you can get the fuse out without removing the motor unit from the case. I didn't have the right tool, so I ended up removing the motor/grinder unit from the case to replace the fuse. The fuse is a 2A/250V Slow Blow. I used a Buss CDC-2A to replace the factory "5TT 2A/250V" fuse.
May 09, 2011 | Gaggia MDF Electric Burr Grinder
Actually iSymphony M110 - it doesn't wont to turn on. Just the stand on red lamp is on and no response on any buttons. Does it has sort of reset button or it should be repaired in service center? Do you...
I just bought one of these "dead" units for $15...I replaced the blown 2A 250V fuse with a new 2A fuse and it blew as soon as I plugged it in so then I took one of the 4A 250V fuses from the other side of the unit(located right behind the speaker output terminals) and it works perfectly now.
Sep 18, 2010 | iSymphony M1 Shelf System
Brookstone Wafer-thin CD with MP3 player circuit failure...why?
sure, ur power amp section is completely shorted. meaning it is totally fried. get it repaired. it was a stupid idea to jump the fuse. u cud fry the whole thing!!! i sincerely hope it is only the power amp. if it is more than that u have only urself to blame. remember looks can be deceptive.
Apr 13, 2010 | Brookstone Wafer-Thin CD System with MP3...
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
My Bose wave radio suddenly is dead as a doornail. It showed no signs of malfunction, just won't work now.
Perhaps it is just a fuse blown. There is one small fuse inside the unit. If the fuse is OK, then the next step might the transformer. If the transformer is OK, then it might be the Bridge rectifier IC GBU series
Jun 07, 2009 | Bose Wave Radio
replace the terminal pcb part # DUNTKB128DE03 you may be having a short in the secondary power supply. you can get the manual here https://www.vancebaldwin.com/shop/research_new/SHA/LC20B2UA.pdf to help you better trace the short. it can also be the main board too better to chase the problem than to make guesses.
Apr 19, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
Sharp Aquos LC-20B2U 20 in. LCD Television Logo
1,944 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
