Whirlpool WFS1072AW 7.5 kg Pump Clean
Needs pump clean but I havn't got the instructions anymore. Could I get a copy of the manual please?.
  • Anonymous May 13, 2009
    I have the same problem. Anyone got the solution?
gregory_91
SOURCE: front loading whirlpool machine WFS1072AW which needs pump clean
WFS1072AW has a clip in panel at the bottom across the front.
Removing this will reveal a black plug on the right.
Unscrew this and water will gush out along with (hopefully) the offending coins.
Posted on Sep 06, 2010
gregory_91
SOURCE: I have a whirlpool WFS1072AW washing machine. a
The WFS1072AW has a clip in panel at the bottom across the front.
SOURCE: Lost the Booklet - Need to Print new one.
I am seventy five and I do not want to join a site with a silly name like FixYa. All you have done so far is to send me on a wild circular search for a very simple request. I want the site where I can download the operating instructions for the above washing machine. That is not asking too much surely?
Jill Briggs
Posted on Nov 25, 2009
  • 89 Answers
SOURCE: Whirlpool AWOE 9559B 1200rpm 6th
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Posted on Jan 23, 2011
  • 4 Answers
SOURCE: Hi i have a whirlpool
Hello Steve.
First off is this a new washer?
If so front load washes ship with retaining plugs / pins in the back. They do this to stablize the drum in shipping so it doesn't get damaged. Check the back and see if this is the case. There should be 4 or so to remove. Also don't throw these out, if you ever need to move you will need them to make sure the washer doesn't get damaged.
Hope this helps.
Good luck
Posted on May 02, 2011
Wfs1072aw
try following this video it's on a bosch but basically the same
Jul 30, 2013 | Washing Machines
LG Direct drive having problems drying clothes
check on the water outlet pump beneath ,,,,,,if there is a sound while drying,,,maybe needs to clean the filter cup,
Apr 13, 2013 | LG WD-1070QDP 7 Kg Direct Drive Washer
Changing pump on whirlpool washing machine WFS1072AW. I need a new pump (so I've been told as the single part isn't available for sale) as I've broken the black screw/cap that seals the pump. I...
take your new pump back and look in the paper for someone who sells used washers and call to see if they have the part u need,they getthe washers for free to remove may have what u need
Sep 17, 2011 | Whirlpool Washing Machines
We have a whirlpool front loader WFS1273BW 7.5 kg We did a wash then went to use it again and it wont open or do the cycle and a F-08 is displaying on the display window what do we do and how do we...
That is an overflow condition.
Check the drain hose and make sure it is not plugged or kinked
Check the wire harness to the drain pump, pressure switch and Central Control Unit
Check and clean the drain pump filter of foreign objects
Check for drain pump failure
Check that the inlet valve shuts off fully
Check that the pressure switch is operational.
Jul 15, 2011 | Whirlpool Washing Machines
Does not clean very well anymore
On this model poor cleaning is typically due to debris in the sump area of the pump that blocks the water intake to the pump. I have put together some instructions on how to remedy this. Follow the link below and let me know if it is helpful.
Whirlpool pump clean out
May 23, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
Front loading whirlpool machine WFS1072AW which needs pump clean
Feb 13, 2010 | Whirlpool Washing Machines
I have a whirlpool WFS1072AW washing machine. a red light comes on to clean pump. I am not sure how to do it
Jan 07, 2010 | Whirlpool Washing Machines
Clean pump
front load washers have a catch basket befor the pump that is easly removed be hind the lower pannel allways un plug appliances be for removeing any covers sears and partselect have some diagrams that may help you will need the model #
Jul 01, 2009 | Washing Machines
Washing Machines Logo
472 people viewed this question
Top Washing Machines Experts
