Question about HP Pavilion dv2500t Notebook
Can't click a key back on my dv2500 keyboard
I took the "C" key off the keyboard of my HP dv2500 (to get some fluff out from under it) and it won't click back on.
I can get the top of the key to slide under the metal keepers, but the bottom of the key is unsupported and is able to move around. Is there any advice you can give. I would love a picture diagram if possible.
Wish I knew what I am doing wrong :S
  • baydenmckenz Apr 19, 2009
    Thanks for your reply. I've pushed it right down until it hits the bottom, but still no luck. I've even removed the 2-piece underside of the key and tried to click it on first and then add the plastic key, but still no luck.
    I'm wondering though if I've somehow bent the bottom pin down too much and this is preventing it from clicking under? There is only one metal pin for the bottom of the key and this pin isn't really high enough for the plastic thing to click under. Does that make any sense??
    Thanks again :)
  • 155 Answers
Once you slip the key under the metal keepers, push down a bit harder until you feel a click. (Sorry, no pics... just "Use the force, Luke")
Posted on Apr 19, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Macbook air Shift key will not disengage. I took it to the Apple store and they want to replace the keyboard. I took it home and took the keys off and checked for anything being stuck under the keys....
    Once a key starts getting stuck on a keyboard, it won't be long and more of them will have the same problem. The easiest fix for is to replace the keyboard. Cheapest place to get one most likely will be ebay.
    Mar 21, 2012 | Apple MacBook Air
    When I press the b key on my notpad I get two letter like bg so how to I fix the problem with my keyboard puting two letters instead of one
    Ideally you would use some canned Air to clean your keyboard.
    if you dont have any then use a paperclip to clean out from under the keys were I'm sure you will find some fluff and gunk
    If this fails
    You need to gently prise the letters off you keyboard from the bottem of the key and clean around them both and replace by pushing firmly down on the top then bottem.
    May 10, 2011 | HP Computers & Internet
    HP Pavilion keyboard key replace
    Please go to this link and select your laptop, the HP dv5-1000, and view video which shows hoe to install the key.
    http://www.laptopkey.com/installation_guides.php
    Hope it helps. Please let me know.
    Thanks
    Apr 26, 2010 | HP Pavilion dv5-1000us Notebook PC
    Hi' I have HP dv2500. When i restart computer, numlook get on
    Start your computer in bios mode (press whichever key gets you into it), look through the bios sections for turn number lock on on startup turn that function off.
    That will fix the problem.
    Feb 20, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
    My keyboard doesnt workon my pavilion dv2500 hooked up another external keyboard and i'm using that
    I don't think a virus did this. You have a problem with the keyboard itself.Quite likely, disconnecting and reconnecting the keyboard will fix this. If not you will have to replace the keyboard. In the meantime, have you tried an external keyboard?
    Jan 17, 2010 | HP Pavilion dv2500t Notebook
    HP dv2500 laptop keyboard issues
    to remove the keyboard, you have to remove all the screws on the bottom that have picture of a keyboard next to them. theres usually 3 but there may be more.
    Then on the top, you have remove the plastic bezel that runs along the top of the keyboard where the bottons are. There may be a screw that holds it down from the back so be carefull and pry it gently.
    The keyboard can then be lifted out. lift slowly as the keyboard and mouse attach with a small data ribbon and you will need to remove it. This of course may not help you as the keyboard has a back to it.
    It may be simpler to just pop off the key with the problem and then pull out the object thats under it.
    Using compresed air to blow it out would be what i would try first though.
    Feb 05, 2009 | HP Pavilion dv2500t Notebook
    2 keys on keyboard dont work
    send it to the manufacture caustamer care and replace it.
    Jan 13, 2009 | HP CPQ175KB Keyboard
    Tops of two keys have come off how do I put back on?
    They can be replaced, with infact the same keys you took off, just Find The Keys, Place any holders it needs in the back of the Key and Apply pressure until you hear a click and the keys will go back on. If you have lost any holders call HP for replacement ones, but im thinking you would get a new keyboard instead.
    Hope This Helps
    Nov 19, 2008 | HP Pavilion N5415 Notebook
    HP Pavilion dv2500t Notebook Logo
    67 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
