My isuzu trooper has a diesel C223 engine i rebuilt myself and i cannot get the pump timing set right any suggestions
Need a injector pump dial indicator to set up lift in pump (movement on dial indicator)0.05mm at correct timing mark on crank pulley 12 deg.
the above is an example for 4JB1 & 4JB1-TC
which are isuzu diesel engines
Pump timing requires the use of a special dial-indicator tool, not readily available. You also need to verify your injector pop-off pressures and QOS/QSSI systems are functioning.
This one needs to go to a diesel mechanic.
