DVD player producing poor colour image
The DVD player is approx 2 yrs old and just recently has started to produce a poor/faded colour image, with some grey shading/shadowing around the outlines of the images. VHS tapes & TV working fine. What can I do to fix this? It gets medium use, perhaps 2hr usage twice or three times weekly.
  • Anonymous Dec 30, 2007
    no colour when dvd is playngg
    Master:
  • 533 Answers
Go purchase a DVD player cleaner. It will look somewhat like a DVD/CD and will clean the read heads. Often the issues is dirt/dust.
Semper Fi,
Z
Posted on Jan 29, 2018
SOURCE:
SOURCE: toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
Posted on Dec 13, 2007
  • 7 Answers
SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Posted on Dec 25, 2007
jerryg50
  • 1691 Answers
SOURCE: Fuzzy VCR Image and Recording
Most of the time, the VCR cleaning tapes are not very good.
Take the VCR to the local TV service shop in your area, and pay them the few dollars for a proper manual cleaning.
After a few years of use, the transport may need a new pinch roller, belts, idler wheel, head cleaner sponge, and some other pieces. Most of the manufactures are no longer supplying replacement parts for VCR servicing, but the manufactures used to sell a maintenance kit for their models. This kit used to cost about $15 to $40 depending on the model of the VCR.
You can research how to do the manual cleaning yourself, but if you are not experienced you take the chance to damage your VCR. The heads, and the guide alignments are very critical. You may also need to change some parts.
If the VCR still does not perform after the cleaning, then there are fault conditions. The machine will then need proper service.
Jerry G.
Posted on Jul 07, 2008
SOURCE: Blocky images on a Toshiba DVd player
Well, this was no brainer. After simply unplugging the device for about 24 hours, everything went back to normal. Seem that the player is still having this problem from time to time, probably Bios related. I have also advise Toshiba support of the problem and the workaround. Hopefully, they will come with a permanent solution to that problem.
Have a nice day
Posted on Jan 02, 2009
TWITCHDADDY
  • 55 Answers
SOURCE: connecting new Sony DVD player to a TV, VCR, & Comcast cable box
wheres the dvd hooked up
Posted on Feb 14, 2009
How do i conect a dvd player to a Model UE32C5100QW
This will depend on the output type(s) of your DVD player.
If the outputs on the rear of the DVD player are Yellow (vodeo), Red and White (left and right audio) then you will use standard Composite RCA cables running to the A/V inputs of matching colors on the rear of your TV.
If the DVD outputs are Red, Blue, Green (video) and Red and White (audio) then you will use Component RCA cables leading to the appropriate inputs of matching color on the rear of your television.
Both of these methods will produce a standard definition image and you made need to adjust your television to get the image to display properly. You will also need to use your remote to switch to the appropriate input you used.
In some cases newer DVD players may have an HDMI output and you can use that to connect to one of the HDMI inputs on your TV. However, this will still produce a standard definition image although the DVD player or your TV may "upscale" the image to try and produce a sharper and cleaner image.
RCA cables, both composite and component, are available at retail stores such as Walmart, Best Buy or other electronics retailers. You can also find them online via Amazon, Newegg or other electronics retailers. Most shouldn't cost much and probably considerably less than a quality HDMI cable.
Feb 28, 2015 | Televison & Video
Poor Colour images/gray/faded etc...
This may not be the solution but its worth a try to asking you. Make sure the player is not too cold. LCD's like to be at a comfortable room temperature. Good luck.
Sep 26, 2007 | Polaroid PDM-0817 Portable DVD Player
Pinnacle S 10.7 DVD plays for for 15 min plus and then image free
Unfortunately I do not know what a prosumer is (do you mean producer?) but what I would do is produce an image file rather than write direct to disc and then use nero or imgburn to burn the disc.(I prefer Imgburn and not just because it is a free open source prog).
Give it a go and get back if the problem remains.
Jul 08, 2010 | Pinnacle Dazzle DVD Recorder
No color when playing dvd
try to connect cables again. make sure you push them strongly to maka sure it works. if that won't work your dvd or tv is damaged
Apr 06, 2010 | RCA Televison & Video
My LG DVD player produces a grainy gray picture that does not appear formatted to fit the TV screen. It worked fine on another TV and an old Apex DVD player works fine on the current TV. I am running thru...
I think it's more likely to be the colour setting. The TV is likely to be NTSC and the DVD player PAL. If the DVD has settings for the TV try switching to NTSC if it is on PAL. Or if The TV has settings to change the colour try that.
Oct 05, 2017 | Televison & Video
Pioneer Elite Plasma TV 2-yrs old loses color randomly.
Would need model number to search properly. On some sets a capacitor "C2601" of Y-Drive assembly contacts the audio bracket and it is damaged, can cause a abnormal picture.
Sep 08, 2009 | Pioneer PDP-5070HD 50 in. Plasma...
Poor print quality....bad fuser???
Is the toner sticking to the paper? This could produce double images (but not mirrored) More likely a problem with a mirror in the write unit out of place, which could create "mirror" image and poor quality.
Jun 09, 2009 | Brother HL-6050DN Laser Printer
COLOUR PRINTING
A thermal printer will only print in black because it burns the image into the paper like a hot iron. It produces a black image because of the surface of the paper is coated. Usually the image fades or goes away after six months.
If you hade a label printer that uses color transfer ribbons, that would work if they have other colors available besides black. I don't know if that is an option with this particular model.
Mar 10, 2009 | Dymo LabelWriter 400 Thermal Printer
COLOUR ON W6400PG
What paper are you using? If the paper is glossy, try matte settings to get a more saturated print
Jun 07, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Ekse
